Check mobile broadband coverage (3 Viewers)
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Thinking of getting a new mobile broadband dongle? This site gives you maps to compare coverage of the major UK providers.
Quite enlightening to see the comparison between your network & the competition. :thumb:
I always thought O2 had good coverage (been with them for years) but in comparison they are way behind some of the others. Vodafone not much better. :whatthe:
lunarman
2,156
2,451
South Glos
since 1994
I have an unlocked dongle with both a 3 and a Vodafone sim. I only use it when away in the van and from experience I would say that 3 has the best signal across the country.
Lunarman
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
Here is a link for three, put your postcode in.
Douglas
2,835
400
South Wales,
Lunarman
Were did you get it unlocked, I have 3 dongles that I woud like to unlock but there is no one near here that does it.
Doug...
GJH
29,450
38,827
None, now sold
2006 to 2022
Can't see a link Keith. Is it me or is it missing?
Graham
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Whatever one you get, they all now expire after 30 days even if you have not used up your useage limit.
I have an older Vodaphone dongle which does not expire for 180 days (no longer available) which works fine at home (Berkshire) and on the boat at Poole but useless at the dealership (Robertsbridge) so I use an O2 dongle there which does expire after 30 days.
The O2 we use at shows all over the country which seems to work fine but won't work at Poole or at home so buy one of each and use whatever works best wherever you are
Peter
Feb 22, 2008
12,266
45,060
Nearly Tugging
I find the 3 dongle beats vodafone, O2 and BT for signal strength and speed.
Douglas
2,835
400
South Wales,
I have a 3.co dongle and a Vodafone Dongle, a t-mobile mobile and I find all 3 of these companies over state the level of there coverage.
If you are in anything other perfect reception then there maps are not accurate.
Doug...
keith
keith
3,421
1,864
Ecclefechan
Graham
Oh bugger, done it again. Here it is: :Doh:
Different one John but looks like the same info.
Edit: Sorry folks been out all day so a delay in correcting my mistake. :Doh:
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
I have been using a 3 MiFi dongle for a few months now, it works fine.
If the signal is marginal it can be helped by raising it a few metres on a flag pole to lift it clear of any local obstructions. As it does not need to be wired to the computer (phone signal in and Wifi to the computer) there is no problem doing this. :thumb:
Douglas
2,835
400
South Wales,
I am confused as to what dongle that you have, do I understand it right, you have something that you can mount on a pole that receives a 3.co signal and then retransmits the signal on WiFi?
Doug...
Douglas
2,835
400
South Wales,
Here you are Doug Link Removed and Here.
Unfortunately its not what I was hoping for, my house is in a poor reception area and I was looking for a external unit that did not run on batteries, that way I could place it 2 or 3 meters above the house to improve the reception. At the moment I am working on the idea of making a normal dongle water prove and running it on a PoUSB cable.
Doug...
gozomike
Funster Life Member
1,001
863
Since August 2008
Sorry for the delay in responding, I have been out & just returned.
Yes that is the unit and whilst it does have a battery in it that is charged via a USB connection so you could do what you are saying with it. Running it at home (when in the UK) I have the USB plugged into a powered USB hub for power. If in the mobile home with it inside I plug it into my laptop 12volt Power Supply unit which has a USB power output, alternatively I can plug it directly into the laptop. I only run it on the battery when it is up the pole to save running a lead to it. So you could just run a USB lead up to the unit for power, the signal would just be sent down by Wifi.
Obviously I do not know how the signal from 3 is at your location so cannot say if the signal would then be good enough.
Ruddy
99
Haverhill,Suffolk
Coach Built
> 1yr
Peter
Peter,
Your quite right that the old ones dont exipre, But they dont expire after 180 days :thumb:
As long as you log on to the net work at least once in every 180 days the usage will never expire.
I took mine into a Vodafone shop to have the content control removed (I couldnt even type Essex into google because it had "sex" in the word :ROFLMAO:)
And the bloke wanted to update it to the lastest software....I told him if he did then vodaphone would be paying for the dongle until I bin it.
Ive had it for 18 months now and im still using the £15 it came with :Blush:
ps dont forget to turn off atomatic updates in the settings.
