funflair
OK I know that this is not the right way to do it but I have been looking at somebodies van a they were having problems with the 12v not working and it seemed to be since they have had a new Solar regulator fitted and somebody connected the starter battery to the "load".
The van is a Bessecar 600 and has a relay to cut the habitation electrics when the engine is running, my question is: "is it possible that this is via a voltage sensing relay (rather than a traditional D+) that then sends a signal to tell the other relay to turn off the habitation electrics"?? if this is the set up is it possible that the "load" terminal is supplying too many volts and confusing the habitation relay into thinking the engine is running.
Martin
Martin
