Its your lucky day.Hallo how best way too charge a e.bike battery when on the road off grid inverter but what kind i have bosch battery on e bike what do i need thanks
Nope, when we went to the Vaucluse, there were 60 places that did it in that area. Museums, bike shops and toursit information places and hotels.That's really interesting (free recharging)
I suppose they're expecting you to eat/drink at their premises whilst they recharge.
************************HOLD THE BACK PAGE.***********************************If you go to here https://www.bosch-ebike.com/en/service/powerstations#country=157&bounds=51.428293140039266|1.8106220445312715|52.98665114412175|8.748488255468772&type=dealer
you can choose your country (Holland) and see where the free Bosch chargers are
With Bosch you have to send a 5v signal to the sence pin as well.DC to DC converter, can take 12volt DC and convert it to 42volt DC for the ebike without converting DC to AC to DC with those losses. They are fully adjustable for voltage and current. Most most 240volt ebike chargers are fairly simple and for the common 36volt bikes output around 5amp at 42volts. Your battery has a built in BMS to control and protect things.
Need a usb feed then???With Bosch you have to send a 5v signal to the sence pin as well.
There is a thread on Fun somewhere about it, not that difficult to do you can use a buck converter for the 5v supply.Need a usb feed then???
Way out of my depth....!
Had a talk on national grid infrastructure by retired engineer today, very interesting but our of my depth before first 5mins!!
That's why I use a PSW inverter.I'm not so sure that it's as simple as providing a 5V trigger. I thought that there were other signals being exchanged between battery BMS and charger to control the charging process. There are, after all, more than three contacts in the connection...
For the price I've paid for my e-bike batteries, I wouldn't want to risk damaging them.
Me too...at 750€ for our Custom built YT eMTB batteries I wouldn't risk damage to them...That's why I use a PSW inverter.
Looking at the ads, I read that the batteries are 320Wh, so 640Wh for two. Your 2 x 110Ah batteries have a capacity of 220 x 12 = 2640Wh, so even with a bit of inefficiency that will be plenty to charge them once or twice. Your 300W of solar will give you about 1000Wh even on an average day, so that will allow you to refill the leisure batteries OK. Also, I think the maximum a 375W inverter will take is 31A, so I don't know where the 50-60A figure comes from.We have just bought a couple of Specialized Vado SLs which don't have removable batteries. I've fitted a Victron 375 inverter and a couple of 230v sockets in the rear of the van with a changeover switch.
This allows us to charge the bikes whilst they're mounted on the bike rack, either while traveling, on EHU, or off grid, if its sunny enough.
We have 2 x 110ah batteries and 300w of solar but I think we'll struggle to charge both bike batteries unless we're on hookup or traveling as the inverter pulls 50-60 amps on full chat.
Until I fit my ammeter, which is hot footing its way from China, all I know is the inverter blows a 50A fuse but not a 60A. Not an ideal way to measure the current draw but thats all I've got at the moment.Also, I think the maximum a 375W inverter will take is 31A, so I don't know where the 50-60A figure comes from.
Can I just ask how you are charging them whilst travelling? As in, have you made some kind of weatherproof exit point for the cables?We have just bought a couple of Specialized Vado SLs which don't have removable batteries. I've fitted a Victron 375 inverter and a couple of 230v sockets in the rear of the van with a changeover switch.
