Ceiling TV brackets
Chris Laing
Bonnyrigg
Dethleffs 7057DBL
Thinking about an avtex tv for the bedroom area at back of MH. We have French Bed style but there is no good place to fit a bracket onto a side wall because the Shower wall is there. So option is to get a ceiling bracket and drop it down.
Does anyone have one fitted and whether or not its practical. I guess I would have to make a small metal plate for the outside of the roof to prevent the bolts from pulling through under pressure as well as putting silkaflex sealant on the outside.
Use adhesive to fix a plate to the shower wall then fit the bracket to that?
6” clout nails. Helpful arn’t I.
I know, I’m sorry I’ll leave NOW. :)
I would rather not touch the wall where the shower tbh.
There is the option of bolting to the underside of the wall mounted cupboards but I don't know if they could take the weight.
I would bolt to the cupboard floor.
The ceiling isn't rigid enough to bolt right through, the roof will compress as you tighten the bolts...its only a foam cored sandwich and as well as looking a real bodge on the roof its a future leak pont.
The cupboard will be plenty strong enough.
This is what I have done with a quick release bracket, though I don't travel with the tv attached to it.
