Carver 3000 stuck on
Caravan not motorhom
Hi, I have a carver 3000 in my caravan. I've turned it on this morning but the twist knob and juts come loose. Heater still lit but no way of turning it off...help
Long nose pliers to reach in and turn it off ?? Not familiar with the heater... Pictures ??
:welco:
Take the cover off then you will be able to access the knob where the control knob fits on.
Thank you, I've turned my gas off from the bottle outside for now, is it really simple to take the front off? Should it just pull or will I need screwdrivers? Sorry for all the questions
This may help..
I understand these are older units, suspect the plastic in the knob has gone brittle with the heat and broken up inside where it fits on the metal shaft..
On our old caravan Carver, I think you just eased the bottom away from the heater by 1/2" and then slid the cover upwards, off a couple of locating tangs ?
