Can I replace this?
York
Bailey 620 Approach
Since 2015
Hello, I've posted before on this subject but got no reply so I'll try again this time with photos.
This is the lock to my gas cupboard. The lock pushes in with some springlike tension although you can't see the spring. When open the lock stands out from the receiver. There was a rubber 'washer' although it's wider than most washers. It used to cover the body of the lock and being flexible, it would push in with the lock when you locked it. It snapped and I tried taping it together but this hasn't worked.
So I took it off and the lock works fine without it. I assume the function of the washer is to prevent dirt getting into the spindle of the lock. I would like to replace the washer but haven't been able to source the washer or indeed the lock anywhere including eBay. Any suggestions for me making an alternative washer or should I just keep the spindle of the lock clean and forget the washer?
Couldn't say with certainty but it will probably be part and parcel of the lock/handle assembly and not available separately.
Stupid idea if you ask me.
How about a large blank grommet and make hole for the lock??
Looks like a trim part with little or no function. Keep your eyes open for a suitable grommet (as suggested) or even the neck & upper part of a polythene container that's a near match. Otherwise don't worry.
It's obviously there for a reason, and that will be to keep water out of the mechanism
Clutching at straws but you could possibly make something similar from a track rod end boot.
Thank you all for your suggestions. I like the idea of a blank grommet. Problem is getting the grommet over the lock. Will keep an eye open for s suitable polythene neck end and will investigate track rod end boot too.
Cheers!
How about something like this
Is this flexible? It would need to concertina up if you see when the lock closes and lies flush with the body when locked. Where did you source it? Might buy one and check it out.
Thanks.
So I took it off and the lock works fine without it. I assume the function of the washer is to prevent dirt getting into the spindle of the lock. I would like to replace the washer but haven't been able to source the washer or indeed the lock anywhere including eBay. Any suggestions for me making an alternative washer or should I just keep the spindle of the lock clean and forget the washer?View attachment 331872View attachment 331871
Superglue will fix that! I use Hafixs which in my opinion is the best but quite expensive (y) Use a cocktail stick ;)
Hi on ebay
PVC SLEEVED CABLE EXIT GROMMET / STRAIN RELIEF / NYLON GLAND * VARIOUS *
I would think that you should be able to remove barrel of the lock
A grommet is flexible in that it will twist but it won't compress.... Unless you use pliers or a vice.
By using one suitably sized flute from a boot it will fit in the groove behind the handle where the original went and concertina as the handle is pushed.
Hi on ebay
It's the handle which needs removing, not the barrel. Removing the barrel will still leave the handle and shaft in situ.
If barrel is removed it may release the Handle and shaft, not being able to see more of the lock its hard to say there also my be a circlip that holds the handle in place
Just for future referece it looks like a Dometic SK5 door and a replacement handle has at one time been available, but in Australia! so it maybe worth a call to Jackson Leisure to see if they have any info!
I've got some Hafixs but will it permit the stretching and compressing required?
It should be fine with a tiny spot, hence the cocktail stick, try to hold it together for at least a minute, then leave after another few minutes you can start to work with it, in 24hrs should be 100% set so no great pressure on it until then.
It's definitely the right handle. But as you've identified, they're like rocking horse sh*t to find! None of the main part suppliers stock it and my email, directly to Dometic, went unanswered. I have to say, the track rod end bootee seems like the most likely solution but I may just do without anything try and keep it clean.
Go to 1:12 in this clip for demo (y)
