Can anyone recommend a robust food-grade water hose? (1 Viewer)
ManTheVan
1,466
2,795
South Devon, UK
Rapido C class
Yottie convert
We bought one of the flat blue hoses on a yellow winder reel earlier this year and it’s already holed where the blue hose joins the filler. Not much cop. Can anyone recommend a good replacement that might last and is easy to store?
ManTheVan
ManTheVan
1,466
2,795
South Devon, UK
Rapido C class
Yottie convert
Cheers guys, but are these the blue food-grade hose? We had a new tank fitted and I don’t want to risk using normal garden hose...
Gellyneck
9,275
18,432
More than toes wet now!
Maybe I'm misunderstanding but what's the risk issue to a new tank?:unsure:
18,046
48,208
I am sure you can get it a bit cheaper but this is the sort of thing we use. The original lasted six years and I replaced it with something similar last year. It may be blue and flat but it is good quality. It doesn't kink or otherwise misbehave like the cheap versions seem to do.
Whatever hose you use run the water through it for a few seconds to flush it out before starting to fill the tank.
Amazon product ASIN B00OH78HU2
www.amazon.co.uk/Super-Water-Grade-Caravan-Motorhome/dp/B00OH78HU2/
Nov 3, 2020
1,293
2,215
Up the Hamble
Ace Siena
Since 2019
Hi. This is what we use
We also have one of those flat "cassette" hoses which we were given and I can see why the previous owner was happy to part with it - near impossible to rewind into the cassette and kinks when you blow on it. I use it at home but wouldn't give it room onboard.
Jim
Ringleader
Jul 19, 2007
36,533
131,561
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Some garden hoses can impart a rubber taste that completely ruins a cup of rosy. The better quality the hose the least likely that will happen.
Last year we spent a long time living in the grounds of a hospital and I bought this Hozelock hose. The problem was the tap was the other side of a busy roadway. This hose must have had a 1000 cars and vans over it, no kinks, leaks or rubber tastes. Perfect. (y)
Amazon product ASIN B00GSAR4MI
Oct 7, 2013
5,910
37,062
South Wales
Swift Escape Compact
Since 1988
Another vote for decent quality garden hose. Flush through before use to remove standing water. Fresh water passing through is only in there for a few seconds so can’t absorb much if anything from the hose.
We have been motorhoming for almost forty years and have never suffered any ill effects and we drink the water from the tank too.
Wombles
10,817
11,149
SW England
A few years now
Have tried the flat hoses that need to be fully unwound & they are faster to fill but like this Brunner 3 core food grade hose pipe as can be used on the roll http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=352276323664 . Had one for 7 years & still like new. Quidco has up to 10% cashback for eBay sales & triple Nectar points (207) at eBay too.
3,697
10,280
1995-2004 & 2017》
As Jim says MAY impart slight taste BUT ain't going to kill you or even give you a nasty bug.
If concerned about colour go to B&Q..... they do a lovely cheap BLUE garden hose.
Mar 11, 2013
1,284
1,691
Gillingham
since 2005
All this worry about the hose and yet the water you're drawing off may of been in the pipe for ages, and the pipe joints may well not have lead free solder.
18,046
48,208
When our flat hose packed up after 6 years (see above) we were in France and I bought some garden hose from a local shop.
We suffered from strongly and unpleasantly tasting water for the rest of the trip. I didn't twig the cause at first and blamed the local water! It was the hose leaching out chemicals. It stopped when I drained down and refilled through a better hose. :)
Jun 22, 2012
3,803
41,051
Sherborne Dorset
Thank you, I have just joined Quidco, I’ve used Topcashback for years. The newer version of the Brunner is blue and grey. I saw a write up after you recommended it when we were in the New Forest. On ebay the blue and yellow ones come up for £34.95 but I spotted in the general section a boxed blue and grey one for £39.99 on enlarging it’s the Brunner from a company in St Ives so that’s Nick’s Christmas pressie sorted. I’m so generous but I’m very fussy about the water in my tea!
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
In my experience, flat hoses only tend to "hole" when they get over-pressurised due to a kink in the hose.
Our first flat hose suffered from this as it kinked at the water fill inlet. This was subsequently overcome by inserting a short length of flexible (food grade) hose between flat hose and water fill inlet so that the flat hose didn't kink. Never had a problem since :giggle:
Sep 12, 2016
2,275
5,052
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
Good job I checked first or I'd be copying any good chandlery will sell DECENT hoses unlike caravan shops
Abacist
3,806
11,245
Devon
N & B Arto 88F Tag
since 2013
We have one of those but I only use it if my basic garden hose is not long enough! It is so restrictive of the flow it takes an age to fill the tank when using it!
Cheshirecat57
3,482
5,590
Mid Cheshire
10 years on and off
I use garden hose for the tank
because of what I have, we only drink bottled water
Reactions: DBK
