Can anyone recommend a decent cable terminal crimper please
MisterB
Essex
Adria 670 SLT
Looking to spend under £30 for a decent cable crimper as I want to start adding to my single battery, no solar Moho. There's lots on eBay and Amazon but a recommendation by someone who has one is better than click and regret .... Thanks
Consider something with interchangeable jaws to give you more options of what you can crimp.
Not a recommendation but something like this…..
Toprema Crimping Tool Kit Ratchet Terminal Connector Plier Crimper 5 Interchangeable Die Sets Insulated Non-Insulated Cable Wire Hand Tool with Carry Bag Amazon product ASIN B0751991LP
Not sure that will do battery cables.
A really good crimper will cost more than £30.
More importantly sounds like you only need it for a short while so I’d be inclined to look to borrow one or if you have a vice go for something like This don’t use a hammer unless you don’t have a vice.
Thanks, I only really need it for the battery terminals as I already have a smaller crimping tool for up to 10mm cable (that I also got from Amazon) to do a 10mm shower cable.
I do have a decent vice .... But I fancy owning a specific tool to do the job, especially if I have to alter in situ cables, and I will be allowed to spend a bit more if I make the treasurer a cup of tea in bed when she wakes up ...
Ah right….if it’s only for battery terminals a hydraulic one.
Sorry i thought you meant you had no solar and would be adding it….that why I sugested one that could do mc4 too
ReaseJoy 10 Ton 9 Dies Hydraulic Crimper Amazon product ASIN B01FQPDCJ4
If you can expand your budget, the more expensive ones have more accurate dies, but for a one off upgrade, cheap and cheerful will probably do.
youre right, i dont have solar yet, but will be looking to add it as part of an ongoing 'customisation' ...... so youre suggestion to look for one that does mc4 is more than helpful, ! assumed the 'generic' ones would also do solar cables. is a specific crimper needed for the solar cables? i doubt i would use a specific solar cable crimper ever again, so a bit more reluctant to buy one of them, was sort of hoping my current (oops, sorry for the pun) crimper would do that job?
it really depends on the size and shape of the dies in your current crimper……
Another vote for the hydraulic crimper recommend by Lenny HB in post #5. Used this to redo all battery and solar cables, easy to use and does a good job.
thats the one i have been considering, but if i need to now buy another one for the solar connectors, i might be better off spending more ? though i did note you had used it for solar - so it might be the one i need after all?
You won't get one that does both.
For solar MC 4 plugs its cheaper and better to buy a male to female lead twice the length you need and cut it in half.
I've had one of these for over 10 years now. It has done everything asked of it.
<Broken link removed>
Probably better to borrow one for a one off job. I made our inverter crimps from copper pipe, soldered the wires in and shrink wrapped them.
If you think that the solder will cause a vibration fracture you really must get your wheels balanced 😜
Boris7 and Richard n Ann may have the answer for you, if you can find a funster local to you with the various crispers you’ll need. 👍🏼
good suggestion, but unfortunately i suffer from tool collectitus ....... i just have to have my own stuff !!!
This is the one I have. Have had it a long time now and other than a circlip coming off it has been great.
Although some of the hydraulic ones here are tempting. I will personally stick with the one I have because It doesn't take up a lot of space and I know I would lose some of the attachments...
Same as me. :giggle:
I have the same hydraulic crimpers, mine were an Aldi special a few years ago.
I use one of these for battery cables great bit of kit.
I agree, bought one on your recommendation. It's small, and better for crimping lugs onto existing cables when access is restricted. I have the big mechanical lever crimping pliers, but don't use them now.
ordered one, same as the one recommended by Lenny HB !
thanks everyone for responding !
I use the same one and have for years. Whatever size I want to crimp, I use a size smaller on the jaws. Never had a crimp fail (y)
Last year, when I was building vans for a friend, he had a set of hydraulic crimps. He never used them once after trying mine ;)
Many tool hire companies have hydraulic crimper. If its a one use only its worth hiring for a few quid a day.
When I first started doing crimps, I used the size stamped on the jaws. I wasn't very convinced by the pressure, so gave all the crimped lugs a good pull. One came off, so it's the next size down ever since.
Thanks. I always felt a little guilty.
I did my electrical apprenticeship and the tools we had back then were different with swappable attachments. was trained to always used the right sized ones. So each time I did this using the smaller size with this tool did make me feel a little uncomfortable.
I also do the tug test on every terminal, and the right size ones quite often moved even if they didn't come off completely.
If the wire doesn't fill the hole up enough it will sometimes pull out.
