Camos dome cracked
Augusta08
Morbihan
Autocruise Augusta
Since 2001
I've got a cracked Camos outer dome, I'll have a go at fixing with the Gorilla glue. However does anyone know of a reasonably priced replacement?
there are loads of replacements available but from £155 upwards..... as far as i can tell..
I've got a cracker Camos outer dome, I'll have a go at fixing with the Gorilla glue. However does anyone know of a reasonably priced replacement?
Be cheaper to repair with a piece of plastic glued inside over the crack?
Try Ebay for outdated sat domes where the system is too old to be updated so they are sold for spares
I bought a new one from road pro about 18 months back, it was £135, delivered, i think trying a repair is a waste of time as they go very brittle with age.
Eric
Don't try to remove the dome, unless you are replacing it as it will be very brittle and will probably crack even further whilst you are trying to remove it.
Worse than an egg shell and 100 plus times bigger.
Been there done that. (y)
Thanks I'm down in Spain ATM so I've gaffa taped it, and it's working ok. I will put some more gaffa tape on when I drive back to Santander. Do it when I get home.
