- Jul 25, 2007
- 2,324
- 10,063
- A Woosh bang
One of the more common electrical questions on forums is : "What size cable do I need "
Go here http://www.aeicables.co.uk/and you can use a free cable sizing wizard, you need to register but it's only a formality.
In order to use the wizard you need the followings information about your installation.
1/ Cable type, (PVC single, multicore etc )
2/ Supply voltage
3/ Direct Current / Single / Three Phase
4/ Total Amps / Horse Power / Watts / or kVA
5/ Length of run(mtrs.)
Armed with this information you can now calculate the size of cable.
As an example
I want to wire a 3kw invertor, my parameters are:
1/ Single PVC
2/ 12v
3/ DC
4/ 3000
5/ 2 mt
Type this info into the wizard and the answer is:
Cable Requirements....
Cable size (sq.mm): 95.00
Max. current rating over 2 mtrs.: 300.00
Actual voltage drop over 2 mtrs.: 0.23
Estimated conductor temperature (c): 57.78
I hope this is useful, it takes the guesswork out of calculations and it looks good when you answer a post
2/ Supply voltage
As an example
1/ Single PVC
2/ 12v
3/ DC
4/ 3000
5/ 2 mt
