Cab night lighting - Accordo 120
Edinburgh
Accordo 120
Sept 2019
Hi guys
on an earlier thread I mentioned that the cab area of the 120 was a bit gloomy (and cool - the nearest hot air vent being midships) once you closed up for the night. I was wondering if anyone had done a owner mod to add additional lights to this area? The heating is not so much of an issue but I would like to be able to use the cab area a little more, preferably with something linked to the MH light switches and power supply ( not AAA type batteries if you catch my drift)
Why not replace the OEM cab light with a suitable caravan / mh fitting? Or first try some LED bulbs in the existing fitting.
Can you run a line of self adhesive led strip across the shelf over the cab ... I have done this with a dimmer, all from amazon
I could, but where did you pick up the feed?
From the existing cab light. I know it's on the engine battery but for the time it's in use it will have little effect (I've done it on the last two mhs & haven't had any issues).
