Cab 12v sockets 2017 boxer
lozbou
north yorkshire
low profile
Hi all, touring Scotland at the moment and have blown my aux sockets in the cab by plugging in a faulty air pump, looked at all the fuses but can’t find a blown one. Any idea if there is an inline fuse somewhere and if so where do I find it. Nothing in the manual .
Hi,
Had the same problem on my 2017 X290 when using the Ducato tyre inflator. The fuse is under the bonnet and yes it is a pain to get the cover off - yes there are three yellow plastic retaining screws that are well hidden - 2 vertical to the rhs of the vehicle and then persuade all the other pipes and cables to let the lid come forward and off.
Check if the F15 fuse has blown, if the Cigarette lighter still does not work then check if the F16 fuse has blown as in my case this was the fuse cigarette lighter hooked up to. Something about LHD vs RHD!!!
Hope this helps speed things up !
http://www.autogenius.info/fiat-ducato-base-camper-from-2014-fuse-box-diagram/
you may need to take care pulling the fuse out - needed a full size set of pliers to get the things extracted - the little plastic extractors that are supposed to be used are of no use at all
Thanks Mark for taking the time with your detailed reply. I will try to get under the bonnet later today. It was my tyre inflater as well, not good. Did they change yours under the warranty.
To be honest - I bought a 12V/ 24V Battery Clip-on Car Cigarette Lighter Socket Adapter 3.6 m/ 12 Feet Extension Cord as it seemed a more reliable and robust approach
Amazon product ASIN B01LW8EVFC
