C-Tourer bedroom TV wiring? (1 Viewer)
Sep 10, 2017
527
541
North Brum
As per the title..
We are collecting our 2018 C-Tourer in 10 days or so, it's the I 149 with the Tv cabinet in the bedroom but no wiring to the cabinet. Dealer is new to Carthago, very helpful but not done that many "mods" thus far. The question is .... do any ducts / channels run behind the bathroom / over the roof from the bedroom o/s to above the fridge or under / between the double floor to the lounge?
I need to find a switched 12v feed and then split the TV signal feeding the lounge Tv and then leave a tail in the o/s front locker for a stand alone sat dish.
Thanks.
Zepp
1,673
3,260
Roaming
7 Years
Sorry I can't help you but if your a memeber of the Carthago Club you could ask on there facebook group Im sure someone has done this before
May 23, 2008
2,469
3,438
Near Durham City
Carthago
Since 1984
There's a good feed from the lounge tv.
Through the false floor above the entrance step, under the fridge (remove the bottom drawer for easier access) which is actually the toilet hatch. This brings you into the wardrobe behind the toilet. From there decide where you want to position your tv. You can also run a 240v feed through here from the socket at the entrance door.
All very easy when you check out.
V
Sep 10, 2017
527
541
North Brum
Thanks for that, a great option. So does the toilet hatch give you access under the bathroom?
May 23, 2008
2,469
3,438
Near Durham City
Carthago
Since 1984
The left side of the toilet hatch is the bathroom but there is a void with enough room to run your cable through to the wardrobe. Remove the aluminium plate in the hatch for your wire run as it's easier.
To the right of the toilet is the back of the drawer at the bottom of the fridge.
Anything else just ask. Good luck but I'm sure you'll find it easy but be careful with the rough edges you cannot see.
V
Sep 10, 2017
527
541
North Brum
Thanks again. Not sure we have a drawer at the bottom of the fridge (van is currently 160 miles away) but pretty sure not. I figured the services would need to run somewhere! Looking forward to sorting it ;-) Cheers
V
Sep 10, 2017
527
541
North Brum
The dealer thinks no loom fitted, this is a Carthago so everything is an expensive option.. Ironically I did spec the rear Tv wiring when I was going to have a Malibu.. The foreman of the service department is checking his tech docs Monday to make sure the loom isn't fitted and hiding somewhere. I guess I will end up fitting the cables as the dealer won't take the time I will and I dislike "visible" cableing.
Most of my working life has been finding solutions to hide cable so not stressed by it, just need to find the voids. :)
