Burstner T680 (1 Viewer)
Apr 22, 2018
6,823
12,578
Herts.
Adria Coral lowline
Does it make 12v socket permanent live, or stereo work whilst ignition is off would be my first thoughts.
Nov 4, 2011
5,939
38,934
Uk
Socket might be missing.. :(
Just so you know you can’t see the socket unless you look right under the rear bumper.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you. Will sort it when I have alarm in van fixed. Appreciate your help.
At one point there was a wire hanging down which a kind funster taped up out of way .. I think the plug missing off the end . :)
movan
movan
21,492
120,753
Moving around
Burstner
since07
@jockaneezer @mitzimad
I know I'm a pain today but when one of you has free time could you give me the measurements please of the round telescopic looking short leg for when the table is converted to a bed. Mind has 'disappeared somewhere' and I need to work out how to have another made ... possibly from wood? What do you think? Does it have any clips on it .. as I have never used it.
Thank you.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
315 long 60mm diameter one end is flat and the other has a 30 mm diameter hole in it its actually a piece of 60mm ally tube with plastic stoppers in the ends if you want a picture/s send me an email
@movan
movan
movan
21,492
120,753
Moving around
Burstner
since07
ours clips into the back of the wardrobe have you checked its not there
Yes . I didnt know what it was as it was loose on bed. I thought I put it in my garage at home but it not there so I wonder if it been thrown away with old stuff. :(
movan
movan
21,492
120,753
Moving around
Burstner
since07
@movan
Thank you I will .. once I find a local joiner willing to take the job on please. That would be very helpful.
Jan 28, 2008
10,116
18,382
Renalt burstner
you want a wood turner really, mind you i could be square it doesnt matter it only holds the table up if you look at the tall leg you have the top will be the same
movan
movan
21,492
120,753
Moving around
Burstner
since07
Yeah ... the garage that does my bodywork has said he can do my sink but I have to find a plumber now to take sink out and put back in... will start looking asap. No rush now. :)
Thanks all for your help. :)
movan
movan
21,492
120,753
Moving around
Burstner
since07
Can I take you up on your offer of photos on here please .. I think I will find someone to give me a quote more easily if I have a photo ... many thanks.
Jan 28, 2008
10,116
18,382
Renalt burstner
joy theres not much to see as it is identical to the leg that under your table just shorter length in previous post
Dec 12, 2010
5,412
21,567
Cumbria
since 2011
You don't specifically need a plumber Joy, someone who knows their way around a motorhome or a self builder would be a better bet.
I started to take my sink out a couple of years ago to replace the tap and it was a bit of a nightmare. Because of the damp environment, when I went to undo some of the screws, the heads just sheared off. I ended up doing a crash course in gynecology and repaired the tap in situ.
