Broken exhaust
Gringo
1998autotrail Cheyen
12months
The exhaust has snapped at the flexible joint on my 1998 fiat ducato so needs to be replaced but I am struggling to get it done round my area burnley does anyone know somewhere nearby
I'm sure it would help if you said where nearby was ?
Coastal motorhomes often comes up as a source of obscure parts.
I assume you've tried your local exhaust specialist
Clamp or weld on Flexi pipes are readily available in lots of sizes so maybe try measuring the broken pipe and trawling ebay
if you measure it you will probably find a local motor factor with a selection, its CES by us but Burnley will have something similar
I have used this service before .
Basically you put the job online and request someone do take the work . I was skeptic but it’s been useful for us in the past . They will every come and do the work at your home address if it’s possible.
My front exhaust section failed recently on my Ducato and I sourced the part from eurocarparts, are you able to at least get hold of the replacement and then just look for an exhaust outlet to fit 🤷🏼‍♂️
Little bit away from you but if you can get there, these are brilliant. Based in Burscough Lancs.
At a push its not that far and looking on their Web site they would be able to do it no bother cheers
