Brake sensor plug (1 Viewer)
May 12, 2016
140
49
Blackwood Caerphilly
N&B Arto
Since 1986
Does anyone know where we can get a Brake pad sensor plug that comes from the loom. Currently trying breakers but no luck so far. Did try to join wires but ECU detecting wrong resistance. Have got someone to do repair but need plug. Have tried Europarts.
TIA
Jan 22, 2013
1,198
51,908
London SE
A class Adria vision I707
since 1971
You could check the resistant in the opposite wheel and put the necessary inline resistors in the cable going to the pads, cover the lot in heat shrink and the jobs is sorted,
H
May 12, 2016
140
49
N&B Arto
Since 1986
The problem is there isn't one on the other Wheel! But thanks
Jun 6, 2022
296
610
Bottesford, Scunthorpe, UK
Autotrail Cheyenne
Newbie
The sensor detects when pads are worn by being worn down as well and shorting circuit, have you changed pads?, from what I can see (not changed them yet) the cable either comes part of the new pads on some versions or as a plug in sensor cable, again not done it yet but on some vehicles you have to reset the fault using a OBD reader to get the dash light off.
Feb 19, 2018
4,131
77,887
EAST ANGLIA
Murvi Morello
Since 1975
Although, I'm told, it's not an MOT failure, I just cut my old one off and replaced both ends with spade connectors.
Apr 22, 2018
6,555
12,069
Herts.
Adria Coral lowline
The circuit will either be open or closed. No set resistance. Join wires together or keep them apart.
