Black plastic smelling smoke from Truma vent
Bridport Dorset
Swift Kontiki 655
Trailer tent for 10 years Motorhome since 2018
Just started getting black plastic smelling smoke from C2002 Truma vent. Has anyone successfully de-coked vent pipe or is it a boiler removal job?
Have you established what your Truma is melting to give you the smell of burning plastic?
I doubt the flue would need decoking if the boiler is running correctly.
I'd stop using it until you can identify the fault.
I don’t think it’s actually burning any plastic , there’s nothing near it to get that hot. Also the smell would be inside as well?
Our boiler smells of a burning plastic when on gas 60 degrees.
No smell on electric or 40 degrees.
Many years ago I had a Hymer with the same problem and asked at a Truma stand at the NEC and there representative said it wasn't a problem as they do get very hot on the higher setting. He said it would shut down if there was a overheat problem.
Thanks for your reply Kuskus, I think I’ll have a go at cleaning the flew pipe, however I don’t think it should be producing black soot in the quantity it is.
Our burning smell is very noticeable inside the van , no black soot from my flue pipe.
If you have black soot it sounds like a problem with the burner itself .
If you’re heater is producing soot deposits from the flue it’s probably the burner is starved of air, this can be caused by a few things, gas pressure at the burner to high, supply air vent partial blockage, flue pipe integrity compromised, to name a few. Make sure you have a working Carbon Monoxide Alarm.
And have this seen to by a competent person. Happy travels.
Thanks for all of your responses, the problem was the air intake going to the vent, new jubilee clip all sorted 👍
