Bike carrier
Ian52
Peugeot Autocirrus
I'm a newbie
I have just purchased a peugeot Autocirrus 220 4 berth. 56 plate. It currently has a big whit box on the back which I wish to replace with a two bike carrier. Advice of how to do please
The white box is on a 90 degree bent tube. I wish to fit a Flammia pro c. I can see the securing on the inside. Just need to know where the supports are
I would expect the tubular frame is already secured to the wooden fixing points built into the vans rear wall.
Only sure way to know is contact the converters, they installed them so will probably tell you where they are.
Thanks. For someone new to mh builds its hard to imagine that the wooden uprights will support a cycle carrier?
They may not be upright. They will be bonded into the foam sandwich before the inner and outer skins are bonded onto the foam
It's quite substantial and considering the floor will be made the same way but with plywood skins over foam.
