Same set up here which I mainly use internally, plus a Solwise 9dbi USB Omnidirectional antenna, which I use externally (but less discreet). However, because I am surrounded by closed and secure subscription signals here at Benidorm, I am using my Three 12Gb /12 month sim card (3G only) soon to be replaced by a 24Gb/24 month year sim card.I've had a cheap and cheerful chinky eBay special with directional external antenna pulled in signal very well £17.
And using an Alpha router. For hot spot.
Same here and have done a direct comparison with an iboost & guess which one worked betterI've had a cheap and cheerful chinky eBay special with directional external antenna pulled in signal very well £17.
I hear that some sites, Bonterra Park for example, visually identify MH's with boosters on windows and the like and promptly disconnect the paid for WiFi as you are deemed to be using more than one device on the account. So covert use and maybe consider a permanent solution on the roof which is more difficult to identify. I have a my own bespoke solution so cannot give appropriate advice in regards to hardware.
My Chinese cheapy does the sameThats where the spare antenna comes in handy ,on a stand I made up ,open roof light sit it on roof ,pointed in the rough detection of repeater and usb lead into laptop .
Doesn't/didn't detect it as WiFi router booster.
EE £25 month 40gb and tether my laptop or tablet in EU or home .no need for mi fi .
Ditto that one please, @A S Richards.An update on your progress next week will be much appreciated....![]()
Purchased and used Motorhome WiFi equipment since Adam & Sophie first started. To my mind any extra cost is cheap at the price considering the help and support they give. in pre WiFi days I found it invaluable in connecting to FOB when it could be found, which was more often than some people may suggest, and these days for example, the WiFi booster greatly speeds up the connection at CampingCar Parks for example. The roof mounted 4G aerial and modem makes it seem like being connected to our home wifi most of the time, both moving and statioary, and sometimes enables a wifi signal even when the phone doesn't
Malcolm
The OP was inquiring about Best WiFi Booster hence the iBoost information we've been giving. However when travelling it's better to cover all options so a mifi box as well. It's not an either/or it's both and use what works well it the circumstances where you're parked.
Mickt
