Luke Coleman
- Apr 17, 2019
- 7
- 12
- Dont own one yet
- Im a newbie
Thanks on the update, makes sense now.O.K. folks, I'm the fool that thought you just plug the invertor into the ciggy socket and "hey presto" hours drive later you can plug the T.V. in and watch. Mind I'm probably not the first or last to think this.
Thank you all for the facts of life.
The best is yet to come, Luke..
No one has used the term generator?I feel the term generator is somewhat misleading, this or similar units are nothing more than a means of storing energy from an external source. Given the size of the capacity you would be better off with a second battery and a 500 watt inverter. Remember you will use around 26 amps @ 12 volt d.c. to produce 1 amp @ 240 a.c. Allow for inefficiency and voltage drop. A new good quality 100 amp battery will only at best give you 50 amps usable power without shortening its service life.
Googlebot did mention the misleading term power generator as that is the term the manufacturers seem to useUKing Power Station 250W Power Generator 60000mAh Battery with Universal Plug for Camping Emergency Outdoor Power Supply
by U`King Light
The confusion is between the technical definition of generator as used by engineers, and the hand-waving use of generator as used by the rest of the world. This device is not a 'generator', ie a motor-powered alternator or dynamo. However it 'generates' electrical energy from chemical energy in a battery, in the hand-waving sense. If you're using Google Translate and your English is limited, this might not be obvious.I was referring to Googlebot’s Amazon link. It clearly references their power unit a generator, if you can tell me how its generates power? That is what i was referring to not the OP post
