Over the past couple of months I have been starting up the engine of my Swift/Ducato to keep things loose. Hooked up to mains, so Sargent charger should be on all the time. Plenty of juice to turn over and start. Leave idling for a minute or so. Habitation control panel showing green charging lamps flashing as usual. If I leave it for 2 minutes, the red battery "warning" light on the dash comes on, and the habitation control panel lights stop flashing. On other occasions, if I rev up the engine the warning light comes on and the hab lights go off. The manual says that the red light indicates a charging problem - presumably relating to the alternator - and to contact dealer. I have repeated the exercise with the mains disconnected, but with the same results. The battery is about 5 years old, and my suspicion is that it is no longer accepting a full charge - which makes the "system" think it is the fault of the alternator.
I would appreciate your thoughts before sending the van in to the workshop.
Thanks.
Thanks.
