- Oct 18, 2007
- 53,489
- 150,259
- Hymer B678 DL
Sorry don't have a link anymore. I used a 30 amp double pole changeover relay. I used a 240v coil relay so it changes over when on EHU as we very seldom use EHU and it saves battery power. If you use mains a lot you may want to use a relay with a 12v coil.
ah! I started reading your thread on saturday Lenny, it’s very good info so I will carry on today and try to soak it in, but my brain is quickly discharging info on a rapid basis these days and Gin may have something to do with itThis is what I did.
Lenny's Modding the new Gin Palace
What temperature do you set the controller to switch on the fans Lenny? On the last van I found set to 35 deg worked well fans came on when ambient was 25deg, so I will start there and see how in goes. I think I set the hysteresis to 2 deg the standard setting of 5 is a bit wide. Sorry @Lenny...www.motorhomefun.co.uk
Hi Diabalo - thanks for that diagram - its been puzzling me too. Where you interrupt the power to the Sargent box via the relay, does that have an effect on the running of the fridge on 12v when mobile or is that feed (the fridge) direct from the alternator via a fuse?I have a Forte and fitted a Sterling B2B charger recently. To stop the alternator competting witht the B2B I fitted a relay to turn off the power coming into my EC400 when the van is running. This relay is activated by +12V coming from the engine. I used the Sargent circuit diagram to identify this and got the diagram below fro another forum.
I know this is not exactly what you're looking for as you are a much later version of the Sargent kit and using Victron rather than Sterling but the principle should be the same
If I have waded in and added more confusion - apologies
What does the Leoch carbon spec says? Absorb 14,7?
Also why have you limited bulk to 10hrs?
That might be without any “apparent” problems. I have heard that the effects of the unwanted loop can be diminished by poor sized original wiring, where the resistance in the old wires reduces the amount of current leaking back to the engine battery. However, if the leisure battery voltage is higher than the engine battery voltage it is inevitable that some of the B2B’s output will be going round in circles.So you are saying that you are running both systems in parallel with out any problems.
There are good reasons for this.I know people like to slag off Gadget John,
I fitted a 150A Mega fuse to the vehicle battery 16mm cable to a 30amp circuit breaker then to the B2B then 16mm cable out of the B2B into another 30amp circuit breaker then to the Victron shunt for the negative connection to the leisure battery’s
I'm not sure about this bit. The positive of what, to the positive terminal of which battery?and the positive to the positive battery terminal
Yep, he hasn't got a clue with electrics, only watch him if you want to know how NOT to do something.There are good reasons for this.
lockdown Has been an expensive time I do agree. I have fitted the Victron B2B charger. Directly from the vehicle battery, I fitted a 150A Mega fuse to the vehicle battery 16mm cable to a 30amp circuit breaker then to the B2B then 16mm cable out of the B2B into another 30amp circuit breaker then to the Victron shunt for the negative connection to the leisure battery’s and the positive to the positive battery terminal I haven’t disconnected anything and it works a treat. No issues with the step or fridge. My control unit is the sargent EC500.
Unfortunately it may not know the leisure battery is full because the charge will also be being fed back to the engine battery. A good B2B will not only be monitoring the voltage, which is a fickle indicator but also the tail current. Both the voltage and tail currents will be affected by the reverse connection to the engine battery.Pausim I totally agree with you about the appalling wiring that Autotrail use but surely If the leisure batteries are fully charged the B2B will switch to float and it would be a minimal amount Of return
Why? You need to protect the cable NOT the b2b. The 30a fuse starts at the starter, then cable to b2b, then 30a fuse after B2B, then cable to leisure. The fuse is always near the source to protect that route of cable. Forget about the 150a to protect the 16mm. And why breakers? If is stuck will do nada. Best is fusible fuse for 100% protection.No a 150amp mega fuse is connected directly to the positive terminal on the starter battery which is purely there in case there is any short between the 30amp trip which is connected before the B2B.
If the cable between the vehicle battery and the B2B gets damaged and shorts out it will damage the vehicle battery, so you need the mega fuse to protect the vehicle battery.Why? You need to protect the cable NOT the b2b. The 30a fuse starts at the starter, then cable to b2b, then 30a fuse after B2B, then cable to leisure. The fuse is always near the source to protect that route of cable. Forget about the 150a to protect the 16mm. And why breakers? If is stuck will do nada. Best is fusible fuse for 100% protection.
You did not read, or misunderstood me. Good luck with 150a mega to protect a 16mm cable. I was pointing out that 150a should be a 30a.If the cable between the vehicle battery and the B2B gets damaged and shorts out it will damage the vehicle battery, so you need the mega fuse to protect the vehicle battery.
I think you might be suggesting that the 16mm cable could overheat and set fire to it’s insulation before the 150A fuse blows to save the battery from damage.You did not read, or misunderstood me. Good luck with 150a mega to protect a 16mm cable. I was pointing out that 150a should be a 30a.
