Emmit
Hi All,
Finally received my digital Multimeter through the post so now have the necessary to check (Confirm actually) that the Batteries in the 'van are FUBAR.
This is what I have;
2 x 110volt leisures wired in parallel.
2 x 55 watt headlamp bulbs wired in series for test lamps
So I have 220Ah of Batteries and 110watts of bulbs which equates to 9.1 Amps.
I intend to put the bulbs on for 6hrs by which time I should have used 55Amps of juice which is a quarter of the available output of the batteries.
The starting voltage of the batteries was 12.63 which I know is a sign the batteries are beyond redemption before I've started.
Other than that, are my calculations correct?
Thanks in advance
Thanks in advance
