Battery Problems
Cheltenham
Swift Bolero 684FB
Since 1998
Around about a year ago I upgraded the 12v system on my motorhome changing to a lithium battery
280 amp Fogstar drift battery
Renogy 30 amp battery to battery charger with 300 watts of solar
Renogy 2000 watt inverter
Every thing has been working fine although I only ever used around 50% of the battery
Use is normally microwave kettle and charging bike batteries phone batteries
I have during the last couple of trips powered the fridge through the inverter
I have been away for a few days and decided to get full use out of the battery so during the day I have had the fridge powered through the inverter and when monitoring the apps both Fogstar and Renogy the battery was discharging at around 2.5-3.6 amps due to the solar generated
The battery had dropped to around 42% this afternoon and being as we are heading back home tomorrow I continued to use the inverter then suddenly the inverter alarm came on and the fridge lit up on the gas the Fogstar app reported over discharge and shut down the Renogy app reported the same over discharge of leisure battery
Not sure what happened as the battery should still have plenty of power
The renogy app has shown the minimum voltage today at 8.9 volts maximum today of 13.8
The Fogstar app is allowing discharge at the moment ( could not turn that on earlier ) voltage is currently 11.2 but no sun at the moment so no more charging cell voltage low 2.759 Hi 2.834 Diff 0.075
Any ideas
How long since the battery was at 100% Soc?
Bear in mind the FS BMS doesn’t accurately detect small (<0.7A) drain which can add up over long periods of time.
In theory a 3A draw will deplete your 280 in about 93 hours.
Is it possible that something else used up the power?
Interestingly today I chased down a 3A draw caused by a faulty after market van stereo system. The installer took a feed from the TV wire, and something has gone wrong with the unit.
Hello, is the battery status source of truth on (for example) a Victron shunt based on telling the shunt the battery initially fully charged?
If both BMS and Smartshunt are correctly set up they will both accurately register a full state of charge. The shunt does it by detecting current flow and voltage, and the BMS does it by detecting individual cell voltage.
I don’t have a smart shunt I only have the Fogstar app to indicate the soc perhaps this is totally inaccurate
When all is well you don’t need a shunt, but I guess when you need to debug it’s really handy. I’d consider fitting one if I was you.
I am hoping that the battery will recharge tomorrow on the drive home I do have a lithium battery charger at home that I purchased from Fogstar when I purchased the battery
I do not use the mains charger in the Motorhome as it has no lithium setting
If your charger has an AGM setting it will probably be OK. Not optimal but OK.
Maybe I should purchase one any recommended that would integrate with my current system
I’d recommend Victron. The 300A, 500A or the BMV 712 (it has a small round display).
When my van is sitting the drive with just low current draw from the batteries the Fogstar BMS can read 20% higher than my Victron shunt, the shunt is the accurate reading.
Is the Renogy smart shunt any good?
I bought one and it failed quite quickly requiring to be reset every few days. They were fair and gave me a full refund. I then bought a Victron...
