- Jul 29, 2020
- 112
- 266
- Coachbuilt
- New to motorhomes, had a camper van before this.
Hi all
Van is an Elddis Autoquest 115.
I’m doing some digging around, basically screwing up courage to fit a Battery Master.
Under one of the sofas is a blue unit which I initially thought was the battery charger, but it turns out to be a battery to battery unit (Schaudt Booster WA 121525). Am I right in thinking this is a Good Thing, as it will whack a good chunk of charge into the leisure battery from the alternator?
Separately in the wardrobe, is a Truma solar charge controller, only connected to the leisure battery. Elddis wanted £230 to connect the van battery to the solar, I thought a better option was the battery master, as I can plug the van in at home or on a pitch and keep both batteries topped up even in the depths of winter.
So getting to the meat of it, is it ok to connect the battery master at the power distribution unit? The wiring diagram says that both leisure and van batteries connect into it, I’ll stick a multimeter onto the inputs to confirm. If this is a reasonable way to go about it, does it matter which negative I connect the battery master to, or do I need to find a separate ground connection for it?
cheers and sorry for the long ramble. Off to find the actual battery charger now. Must be in here somewhere...
Rob
Rob
