hi ,,can anyone tell me if its possible to fit a battery heater ,,mine didn't come with a heater ,,and someone said that lithium dont like being charged in the really cold weather ,thanks
ahh ,,thanks ,,i thought i would damage the batt if i charged it during cold weather ,,so i will forget the heater stuff,,My Predator Lithium does not have a heater so I fitted thermostat controlled wrap round heater pads , actually water tank heater pads .. Falcon from Amazon USA.
A complete waste of time !! my O my.
Not needed at all !!
Lithium have internal protection to prevent charging if the battery temperature is 5°C or less, there may be a slight differnce between manufacturers.
Once cut off is reached Lithium will only resume charging once battery temperature reaches 7°C.
So heating is only needed to charge your Lithium in very cold conditions; wild camping with solar or EHU.
So for my use .. in storage over winter, I leave the EHU on all the time to maintain the leisure Lithium on a Victron AC charger(has a 4 stage Lithium maintenance program), and the Lithium trickle tops up the vehicle/engine battery.
Call me a La La but I would never motorhome anywhere in such
brrrrr-cold conditions.
In UK if we are in the motorhome - in extreme cold weather, we'll whack on the heating and hot water 24/7(eco water for night time); the heat from the heating/hot water boiler is enough to keep the battery cosy .. and stop the safety valve dumping my water. Hope this helps.
we have home storage batteries, last January we had one morning where the battery (14.3kw) wouldnt discharge for about three hours until it warmed up. FYI it didnt suffer any damage and still works to its full capacityahh ,,thanks ,,i thought i would damage the batt if i charged it during cold weather ,,so i will forget the heater stuff,,
Yes it will damage it, the message above was hinting that no solar at night, therefore no charge. Your charging sources should be set not to charge bellow 5C deg. That is the protection for cold. When temperature rises above that, it will resume charging.ahh ,,thanks ,,i thought i would damage the batt if i charged it during cold weather ,,so i will forget the heater stuff,,
Have a look at your Seplos BMS with BMS studio. Enter password 000000 as log in to modify settings. Check low temp for discharging: it should be -20C.we have home storage batteries, last January we had one morning where the battery (14.3kw) wouldnt discharge for about three hours until it warmed up. FYI it didnt suffer any damage and still works to its full capacity
Excuse my ignorance but, how do you stop the alternator charging your lithium battery when driving on a freezing morning.
Is there a automatic shut off in my 460 Drift lithium battery to stop this?![]()
I don't know about your Drift battery, but both the BMS on my battery and my Victon gear shut off any charging of my battery below 5c.
It does in my case, as my B2B charger is stopped from operating until the battery temperature rises above 5c.When this happens, does all the Alternator charge go to the Starter battery?
L' Hobo. Same set up for us (as above) Owen, especially as our Drift Eco batteries do not have built in heaters. Your Drift 460 probably does have them, however, the BMS will still prevent charging until the cells reach the required temperature.I don't know about your Drift battery, but both the BMS on my battery and my Victon gear shut off any charging of my battery below 5c.
Ditto here Owen.It does in my case, as my B2B charger is stopped from operating until the battery temperature rises above 5c.
I would contact your battery manufacturer/supplier Owen to get clarification on the details of your particular batteries specifications.
You set your B2B not to charge bellow 5C.Excuse my ignorance but, how do you stop the alternator charging your lithium battery when driving on a freezing morning.
