Minxy
- Aug 22, 2007
- 35,067
- 76,334
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
We've had lots of different BBQs, both gas and charcoal, but now if we want to BBQ it has to be a gas one, too much messing about with charcoal and it actually doesn't do anything to improve the taste, in fact it can be the opposite! Similarly the lava rock you get with the gas ones doesn't help either, it is just more mess to clear up. The BBQ flavour, as has been mentioned, comes from the fats/juices hitting the hot surface/flames, not the coals, lava rock etc therefore you are only really BBQing when you use a proper BBQ rack (ie metal wire type) and NOT a solid griddle/hot plate. However, 'proper' BBQing is messy, whereas the griddle/hotplate is much easier to clean and cooking on and it gives those 'men who must play with fire' the feeling of being in control of something 'wild' but without quite so much of an after-nosh cleaning chore!
We've had various gas BBQs, including ones like that which Devon Bee Keeper uses and its more upmarket cousin which was better built with a warming shelf too and a burner that lasted a lot longer, in fact I think we've still got it kicking around somewhere as we only stopped using it due to it being too large for our van conversion, instead when we want a BBQ we have one powered by the small aerosol type gas canisters which fits in a suitcase, just a bit bigger than the similar suitcase stoves. It works very well but can be a bit messy to clean up (you can stick it back in the case but if you stand it on it's side you can get a bit of gooey mess oozing out!) so at present we take a single suitcase aerosol type stove and hubby uses either a large frying pan or griddle pan on it, and we've found that this produces very good results - in fact you simply cannot beat the taste of chicken pieces cooked in the frying pan with crispy skin ... something you do NOT get on a BBQ without it being half cremated!
