Bailey Autograph - Rusting rear lights (3 Viewers)
138go
3,276
14,613
Carthago 138
Since 2001
Nothing surprises me on MHs. Took me 2 days to change a brake light bulb.
Paul and Kate
2,090
11,027
Stoke on trent
Auto sleeper Warwick
Getting replaced under warranty
Autograph 75-2
Feb 20, 2017
852
2,457
Kent
Bailey 75-2
Tugger now Motorhome
Replaced under warranty- why they are not plastic heaven knows. They don't actually do anything - just a trim.
456
283
Devizes
Bailey 79-4t
Since 2016
Somebody on the TBMOG had them sand blasted and painted in Peugeot white and they look quite effective. I suspect Hammerite finish will do the same job
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Caravan owner moved on to Motorhome
Got a set of replacements - same metal. Coated them in AutoGlym resin polish before putting them on. Doubt they'll last a 12 month.
Jaz007
4
Redcar
Bailey 75/2
Hi how did you get them off van.i was told bonded on.thanks
Oct 25, 2015
456
283
Devizes
Bailey 79-4t
Since 2016
There’s a lot of coverage of this on THE Bailey motorhome owners group FB page. As above with getting them off. People have been getting them sandblasted etc. Once rubbed down some have done them in Peugeot white and it looks smart. Also less than 3 years old then they have been accepted as a warranty issue.
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Ahhhh mine is a 2017/18 - very different. Look up the thread a bit and you'll see the difference.
Wow what a difference !
Don’t fix if it’s not broken comes in here don’t it, mine are lovely
Aug 7, 2019
132
207
Worcester (UK)
Autograph 794-T
I'm a newbie
Hi Paul. I also have a Autograph 79 - 4T (67 reg) and recently spotted another issue you may want to have a quick look at. I recently noticed that the clips that secure the skylight right at the front of the van and over the drivers / passengers heads were ALL put on upside down and when closed put significant stress on the swing hinged clips. I thought it didn't look right and I really had to pull the skylight down hard to lock it. I visited Marques at Tewkesbury who confirmed my suspicions and also confirmed that if they weren't turned around the stress would soon crack the skylight. Yours might be fine but the monkey that fitted mine fitted them ALL upside down and I wonder how many others he may have c**ked up? I can provide a photo tomorrow if required :)
Jan 28, 2008
10,117
18,385
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
god knows where baily sourced metal light from must have bought a job lot when bmc went skint
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Hi Kev. Yeah if you have a photo it would highlight the issue. Thanks.
Aug 7, 2019
132
207
Worcester (UK)
Autograph 794-T
I'm a newbie
OK. I'm popping down to the van in the next few days (maybe sooner) and will obtain and post a picture.
Aug 7, 2019
132
207
Worcester (UK)
Autograph 794-T
I'm a newbie
Hi Paul, as promised here are a couple of images taken AFTER I turned them around the correct way. Hope this helps.
MisterB
5,886
13,196
Adria 670 SLT
I have a 2015 and shortly after buying it had the annual hab test carried out and was told a cupboard door was sticking and they offered to fix it for a price of course.i decided to decline and did it myself- the bloody handle was on house down!! Simple fix though ....
Master vampire
Lee Perkins
bailey Autograph 79 - 4 T
Autograph 75-2
View attachment 331196View attachment 331197
Hi, i had the same issue. Hope this helps. I used 240 grit wet and dry paper, rubbed down removing rust, then used car primer spray allowed to dry then painted with car paint, i used matt black but you use whatever collour you like. Worked very well.
