Axle weight vs gross weight (1 Viewer)
Jan 18, 2024
4
just-looking
Hi all, I have a single axle trailer plated to show a 4000kg maximum gross weight, but the maximum axle weight is only 3000kg. Does this mean the MGW can actually only be 3000kg?
May 14, 2021
1,733
2,770
East Yorkshire, UK
ADRIA Twin 640SLB
Since 2012
I’m not sure but when connected some of the weight will be on the tow bar thereby reducing the weight on the axle so perhaps it could be 4000k in hotel?
Jul 29, 2013
9,071
18,560
Salisbury
Hymer B678DL A class
since 2011
To me the weights sound wrong I would think 4000kg would be max gross weight and axle weight 3000kg that then allows for net weight of trailer🤔
so max gross is 4000kg😊
Jan 2, 2017
667
1,948
Buckinghamshire
Globecar
Since 2010
You're gonna need a bigger axle! :LOL:
I think you're right, yes. There is also the noseweight of the hitch, but that is relatively low - maybe circa 75kg.
Jul 29, 2013
9,071
18,560
Salisbury
since 2011
I’m surprised you can get a single axle trailer For motorhome with that axle weight🤔
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
3T on a single axle, it must be a very heavy duty trailer, out of interest whats the load rating on the tyres?
and as far as i understand it if the max axle weight is stated as 3T then thats the MGW.
Dec 31, 2021
511
440
Adria matrix supreme
That may be the mgw. but what does it weigh empty against what you can tow with you're mh and keep under the train weight. The payload available on the trailer could be real low.
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
The op has not mentioned towing it with a motorhome
tonka
10,834
21,543
Cannock, Staffs
A class Burstner 800
Since 2000
The trailer and it's load 4000kg
Max load on the axle IE payload 3000kg so I suspect the trailer itself weighs 1000kg.
I have a single axle ifor Williams that is 1400kg with an axle load of 1000kg. The trailer empty is,........... 400kg 👍😁
Must be one big trailer.
Sep 26, 2013
4,170
5,156
Market Rasen
Self Build
Since 2003
And 2 big wheels
L
Jan 18, 2024
4
just-looking
Thank you. I was thinking along these lines too, but the maximum imposed load is 1000kg which empties the unladen weight is 3000kg 😩
L
Jan 18, 2024
4
just-looking
Implies not empties
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
A photo of the weight plate might just clear this up!
Reactions: f6c
