Hi,
I erect the drive away awning first and then move it into place and slide the 2 figure of 8's in, align and then peg out the 'tent' and then last the tunnel wings.
Here is ours when I have just pegged out the awning - last will be the tunnel wings (which are not yet pegged on the photo). You can see the two figure 8's in.
Hope it helps.
Trikeman.
I bought one of these from John's Cross for our driveaway awning - it works a treat :thumb:http://www.johnscross.co.uk/fiamma-drive-away-fixing-kit.html
Fiamma Drive Away Fixing Kit Figure of 8
Fiamma/Omnistor Drive away fixing kit OR532.
Designed so one side of the fixing kit slides into the channel at the front of a Fiamma/Omnistor wind-out awning, and the other fits into a figure of 8 track for attachment of driveaway and caravan awnings. [HI]6mm beading one side 4mm the other, most awnings use the 6mm beading for attachment to an awning rail, this kit allows you to join to the smaller size used on the front of Fiamma and Omnistore cassette awnings.[/HI]
Simply slide the narrower length of twin piping into the channel of the wind-out awning. Now slide the figure of 8 plastic strips onto the opposite side of the same twin piping section. The opposite side of the figure 8 simply slides onto the piping sewn onto the back of your awning.
Kit comes complete with 3 figure 8 pieces and 2.0m of tape, if you have a longer awning, you can increase by purchasing more kits.
