Awning brackets
Trout bum
Ayr
Adria Matrix M670SL
Anyone have awning brackets fitted to side of their van to fix the awning feet to the van rather than the ground ? Are they any good ?
How did you fix them on May I ask I believe you can screw them on or use fixing sealant and are they plastic or the aluminium ones
lots of differing advice on here. Just use small csk self tappers in the plastic as the load is in compression with slight shear. We never had any problems even when windy.
J
I was worried that we only have a thin outer aluminium skin on our van, so I painted a couple 100mm x 100mm x 2mm stainless steel plates body colour and bonded in place and screwed the awning feet brackets to them to spread the weight and forces coming down the awning legs in case of wind gusts.
There was a recent thread where suction based fixings were being used rather than needing permanent mountings.
I used self tappers and sikaflex.
We love them, use them a lot. Attached with rubber seals,screws and backing plate provided in kit.
Yes and yes.
Contrary to what has been said, the brackets can and will take high tensile forces when the wind starts to blow and gets under the awning. That is why awnings can be blown upwards and over the motorhome in a strong gust. Seen that happen and seen the damage it causes. Self tappers may be OK for steel PVC walls, but won't take much tensile load when going through the thin aluminium of a coachbuilt motorhome. I bolted mine through the wall with stainless steel panhead bolts and large flat spreader washers on the inside wall. Also used Puraflex to seal and glue on the outside.
When ours broke (ageing plastic) I bought replacements. The kit included metal backing plates and spacers for the walls which (a) prevent compression of the wall sandwich and (b) make a very strong fitting, perfectly capable of coping with unexpected gusts. Rather than disturb the sealant I just used the old backing plates.
Excellent for when you can't get a proper tie-down or just want a portion of the awning out. However I still wouldn't leave them out overnight or unattended, that's a huge "sail" to catch the wind.
Downside is I keep forgetting and walk into the legs! :banghead::banghead::banghead:
