Avtex TV Aerial. Which direction
Emmit
Cornwall
Pilote Explorateur
Jan.2014
Morning all,
Our 'new'??? Van has an avtex TV. I have purchased an Avtex Aerial to go with it.
I'm sat on the drive at home, put the aerial on the roof and scanned the TV to get a signal. We are, 'Line of sight' with our local TV mast at Caradon Hill.
I received loads of signals but here comes the question.
When I set up the aerial outside, (the photo is for ref. only) I had the aerial facing the mast thus:
I then turned the aerial so that it was at 90 deg. to the mast and I continued to receive all the channels, thus:
However, when I switched off the signal booster, I continued to receive a good reception BUT when I returned the aerial to facing the mast I lost reception.
This seems counter intuitive, but hey! what do I know? (Bugger all is the answer!)
So that's the question. I appreciate that there is also the question of whether the aerial should be upright or horizontal. If I could be guided on that as well it would be appreciated.
Over to you and, as always, thanks in advance for your responses.
Try app on phone UK aerial alignment. I've used it all over UK. Don't forget if you have a weak signal even this info won't help.
You need something like this Derek, you can try various positions with the antenna and see what gives you the strongest signal.
