Avtex 19" Digital television
West Sussex
Adria Coral
Im a newbe
Hi all and just wondered if anybody could tell me if i am doing something wrong ! I bought this model of television as i thought it was a one button auto scanning television as the wife and i are not very good with these gadgets and struggle to tune it in when we arrive on different sites around the country ! Many thanks.
I can confirm that you are doing something wrong, you just press the big button in the middle of the remote. You need to make sure that you have a decent signal though first.
What aerial do you have or are you plugging in to site?
If MH aerial are you adjusting it when you arrive?
If site, how does it connect to the MH or TV?
Is there a button that has the letters AQT on it ?
Try going into tuning settings & activating the signal booster, then try tuning in again.
What sort of antenna are you using, the old flying saucer type are really poor, we have direct line of sight to our transmitter & it still wont find signals, I've just bought a Vision Plus 530 cos I want DAB radio as well as TV.
If your using a Status 530 or 570 type antenna, remember that it needs to be pointed at the transmitter as well as correctly set for horizontal or vertical.
Getting a little over complicated here . I think the OP is just asking how to use the Avtex auto tune and is looking for the AQT function to tune the tv in the future when travelling around
Thanks for that guys and i have loaded D.T.V Antennas on my phone but no compass just some arrows pointing to local signals which stay in the same place if i turn my phone around ! .
Can you post a picture of your remote control? What model number is your avtex if not?
Thanks for that guys and i have loaded D.T.V Antennas on my phone but no compass just some arrows pointing to local signals which stay in the same 0lace if i turn my phone around ! .
The new Vision Plus boosters have a light system to tell you when your pointing correctly at the transmitter, they are not expensive at around £25 to £30 & save a lot of hassle.
Try antenna finder app. Or go outside and look at other peoples in houses.
Hi all and yes its the big red button AQT in the middle of the remote and also fitted with a Vision Plus Digital Amplifier and Radio V.P.S. plus my Ariel is the wedge shape one which can be turned round and tilted ! .
As already mentioned, take a look at the aerials around you, position yours as the surrounding ones are and a long press on the AQT button should have it tuned in a few minutes.
Assume you move the aerial every time to find the green light? (Or as best as possible)
And you are aware some areas require flat position and others require tilted to one side?
And your aerial cable from the tv is plugged in the correct socket on the MH, mine has 2, one is connected to the onboard aerial and the other runs to the an external connection point?
