Autotrail Tracker EKS 53 plate Vin and axle weight plate (1 Viewer)
HOGGY
10
Gretna Dumfries and Galloway
Autotrail TrackerEKS
Since 2007 on and off
Hi Folks does anyone know if there is a second vin plate on the Tracker? The plate in the engine bay says the max weight is 3000kgs, the handbook says 3400kgs, the V5 says 3500kgs, I'm confused and I'm wondering if there is an Autotrail plate hidden somewhere. I'm thinking I might need to uprate the van if the 3000 is the only plate.
Any advice will be gratefully received.
Feb 2, 2015
2,282
7,330
Shropshire, UK
A motorhome!
we are still learning
42,954
46,964
There should be a Fiat (Assuming it's a Fiat) plate (1st build)
There should also be an converters plate(2nd build)
It doesn't have to be a metal plate and it doesn't have to be under the bonnet.
Look in the door well or wardrobe etc.
Are you certain the plate is 3000kg and not a badly stamped 3300kg or 3500kg.
It's the first time I've heard of one at 3000kg.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Our Autotrail Tracker had two vin plates as far as I remember.
Makers and Convertors
Our IH definitely does. (y)
