Automatic water dump (1 Viewer)
Candapack
711
2,639
Fife, Scotland
My van has thus feature, where if the temperature inside falls below 4' C, (I think), the water in the boiler is dumped. It's linked to a thermostat near the cab.
If the water heater is on, will that prevent the valve opening regardless of the temperature, or if not, does the water heater automatically switch off when the water is dumped?
TIA.
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Our latest van has this feature, the dump valve is next to the water filler in a compartment. When the heating is on it actually feeds hot air via a pipe to the valve. If the water is dumped from the heater, it will not ignite again until the valve is closed manually and the tank re-filled.
Hope this is of some help.
Keith :cool:
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
If you switch the boiler on, it wont dump.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I think it depends on which heating system you have.
The modern Truma Combi systems have no direct connection between the dump valve & the heater/boiler as standard. They can be used to heat the van whether or not there is any water in the boiler, so no, they don't stop working when the water is dumped (but obviously you won't get any hot water either!).
As standard, they depend on the heater being on & warming the air in the van enough to prevent the valve opening. You can get a valve heater that draws power from the boiler electrical supply so that as soon as the heater is on, it warms the valve up enough to keep it closed, even if the rest of the air in the van is still below 4 degrees.
In my van, the valve is in the bottom of the boiler compartment. I think that is partly so that it will come up to temperature quite quickly once the heater is on, but mostly because it's just a handy place to open the pipe to drain the boiler. The heater is linked to the thermostat, but the dump valve isn't - it just reacts to the temperature around it.
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
Dont forget to fit a peg for the summer, stops the wife accidently dumping boiler when searching in compartment.
Sep 26, 2013
4,170
5,156
Market Rasen
Since 2003
You can change it for a manual one as long as you remember that it won't dump on its own.
