Auto trail update (3 Viewers)
Inthezone
146
105
Berkshire
Hi All a while back I said that we were having some work done on our van, well its been done by VanBitz last week the updates were
  • Additional solar panel with regulator
  • two new Banner batteries
  • new Pioneer double din head unit (DAB) and bluetooth
  • Dometic air con
  • extra 240v socket in media area cuboard
  • waeco 2Kw inverter (with auto switch over)
  • Sat TV to rear bedroom
Eddie and his men made a brilliant job of the work, everything was discussed and agreed beforehand and it was all finished on time and to a standard second to none.
We were aprehensive about letting people loose on our van after havig a really bad experience at the dealers last year where some of our personal belongings were stolen from the van, but I must say that the respect and care Vanbitz took with our second home was really appreciated and I would recommend them to anyone.
Scout
3,959
121,448
South Yorkshire
chic c line
  • Dometic air con
how does that work then, is it
IE if no mains input found, switches to inverter which powers all van scokets? is that correct
Inthezone
Inthezone
146
105
Berkshire
inverter
Yes thats exacly how it works, there is also a main overide switch to turn off the inverter if I do not want it on whilst on batterys, an inverter will consume a small amount of power when its on and in standby mode.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
You now know why people say only good things about Vanbitz :thumb:
Scout
3,959
121,448
South Yorkshire
chic c line
when the inverter is ON does it switch the battery charger in the sargent unit OFF?
golly
2,006
69,657
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
  • Dometic air con
I,m off to Eddie's next week to have an alarm and solar panel fitted to our new van, Ill be travelling solo as Mrs G has grandson sitting duties. 670 mile round trip, so it will give the van a good try out. Going to stop somewhere on the way down and back, and have a couple of nights at Eddie's.
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
We are booked in on 6th June for a strikeback system to be installed on the new van. Deja vu - same thing on the current one............:thumb:
eddie
8,160
41,285
Taunton Somerset
RV
since 1989
No need. The "ring main" is isolated and only that is wired through the automatic transfer system.
So many times we see an inverter plugged into the mains input:Doh: so the charger is running off the inverter, trying to replace the power that the inverter is using so drawing more power from the battery for the charger :roflmto:
Perpetual motion doesn't exist :winky:
Mar 29, 2011
961
639
Rugby UK
C Class RS
I had an inverter fitted and I have a rocker switch with red/green lights as a low battery warning but before I switch that on I have a master switch with 3 positions, 1 "off" which is for normal use, 2 "mains" for when on EHU which is all 240v live, 3. Marked " Inv" which makes all the 240v live from the inverter, I wish I had a auto switch over as one of the things I have to remember is to switch the fridge/freezer from auto to gas having learnt my lesson when having had the inverter on and discovered it was running that as well:Angry:
Scout
3,959
121,448
South Yorkshire
chic c line
That what I was thinking. Im sure I need you services whether its on this van or the next
Inthezone
Inthezone
146
105
Berkshire
First try out
Well what a fine day yesterday air temp around 26 degrees and hotter in the direct sunlight so we deceided to try out the new air con fitted by vanBitz it worked very well dropping the internal temp from a max of 27 degrees to 20 in about 45 minutesor so
very pleased with it :Smile:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
do you have a stand alone awning?:Eeek:
