All
Just thought I would let you know the experience I have had with buying some Artic Yellow cable to use a new hookup cable.
After having issues winding up the standard orange cable after a cold night I though it would be a good idea to invest in some to the Artic cable which is supposed to remain flexible down to -40 according to the BS. So I ordered some from Toolstation the other day £67 for 50Mt, not the cheapest and not the most expensive but as I have used the like of Toolstaion before a safe bet I thought.
The drum arrived and when unwinding 25Mt I did think it was a little stiff but put it down it being on the drum a long time. After cutting the cable and make the new commando plug connections I did think it was very stiff and not like any Artic cable I had used before. So I thoughtI would give it a test. I cut off 1Mtr and put it in our freezer which is set a steady -15. After 30 mins I took it out and it was a stiff as iron rod, hardly flexible at all without a lot of effort. The cable drum was marked up with the correct EN and CE markings but clearly doesn't meet the specification.
I did email Toolstaiton customer help but no response and I have email the manufacturer Pitacs so it will be interesting what they say.
So if you fancy a flexible winter hookup cable best to go down to your local electrical supplier and feel before you buy so you don't waste your time and money like I have done.
