As above - That is an expensive battery.I hope it will last forever at that money
Looking at it again it doesn't look like a motor battery or leisure, as Stealaway says above I would just use it as long as it works then get two new ones for similar price.This is why I’m asking as I want to add another battery & been told the batteries should be the same
I’ve only been out in this van a couple of times, the battery seems ok, I will try to find a date stamp later today , as usual the battery is no easy to get too without being a contortionistAs above - That is an expensive battery.
I would hope to get 5 years out of my 130Ah lead acid battery I buy for just over a £100 ---- although I do know how to look after them.
Do you know the age and condition of your existing one?
Wait until this one is gone and buy a pair different ones?
Batteries should be the same chemistry....lead acid/gel/AGM/lithium.....and ideally the same age but make and capacity are not important for our purpose.This is why I’m asking as I want to add another battery & been told the batteries should be the same
So I could I just put a any lead acid battery of the same size in?Batteries should be the same chemistry....lead acid/gel/AGM/lithium.....and ideally the same age but make and capacity are not important for our purpose.
The charger only sees one big battery no matter how many are linked.
I would leave it for now and just fit the solar panels ASAP.So I could I just put a any lead acid battery of the same size in?
I think it's the other way round. If it's 100Ah at C10 then at C20 it will be more, probably 110Ah to 120Ah.Looks good to me good brand and no CCA rating so not a starter battery.
It's probably only 90ah as the rating is given at the C10 rating.
Always better to use the same, but they should also be equal in power when charging, or one will always be under charged or over charged, that way you could ruin one battery (life of one will be shorter than the other) I would wait until the one you have is not fit for the job anymore, then get two new, than charge each one until the same power rating, then fit.This is why I’m asking as I want to add another battery & been told the batteries should be the same
It's 104ah @C20.I think it's the other way round. If it's 100Ah at C10 then at C20 it will be more, probably 110Ah to 120Ah.
