Arapaho Fog Light (1 Viewer)
Micky 2 Bel's
26
Kent
Hi All.
I've got a rear fog light bulb not working, but for the life of me I cannot see how to change it without taking a lot of the back end off. I can only just about get my hand to the back of the light, there's got to be any easier way of changing this bulb.
Help greatly appreciated.
Many thanks
Mick
ambulancekidd
Sep 23, 2014
10,073
28,054
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
I don't know for sure but, I'd hazard a guess that you unscrew & remove the light cluster above the fog light to gain proper access.
Remember though, its just a guess & I've been known to be wrong before but, that's where I'd start.
Micky 2 Bel's
Micky 2 Bel's
26
Kent
Thanks for the reply, but behind the light cluster are three very small holes just big enough to fit the wiring through let alone anything bigger.
MikeD
3,936
3,697
London
IH PVC
Since 2012
My 2012 tracker rear lights was just held in on spring clips. I found this on the internet and it worked for mine. (y)
"To remove the light you need to insert a small flat screwdriver between the plastic and the bottom edge of the light. I would place a cloth between the red plastic and the screwdriver so you do not mark the plastic. You will see a narrow slot in the base of the light. The light is held in place with a spring clip."
Micky 2 Bel's
Micky 2 Bel's
26
Kent
Hi MikeD
I will try and give that a go, but the light cluster on your 2012 are a lot different to mine. Thanks for posting.
