Is it possible to fit a battery shut off switch from the starter battery as a form of extra anti theft. Or would it be better to fit on the feed to the starter motor as I assume this would not affect the alarm, immobiliser and tracker.
My friend fitted such a switch that he hid in the glove box of his car( a convertible escort 1985 vintage), very successful. Except that he had forgotten about it after a time and had thrown a book in his glove box and spent the next hour trying to get his car to go, a red face was the result when he discovered his mistake!
Such critical switches in an aircraft have to be fitted with a guard, which stops inadvertent operation as the guard has to be lited to operate the switch.
Geoff
Many thanks to all. As suggested I think the fuel route is the safest and most effective way.
I am also planning on Outsmart The Thief.
But everytime you forget you have to replace the fuse. Double edged sword.If you fit to the starter a cut out switch you then need to add a fused link wire around the switch to maintain all the alarms ,radio codes, clock ,etc. Any attempt to start will fail when switch is removed & fuse will also blow on the low amperage by pass.
My road/track car has an isolation switch it cuts off everything including pump ecu etc. You will see all track cars with these as a battery isolation is a safety requirement. However I would not do this on my MoHo you would probably be better off speaking with eddievanbitz for a non starter solution.Is it possible to fit a battery shut off switch from the starter battery as a form of extra anti theft. Or would it be better to fit on the feed to the starter motor as I assume this would not affect the alarm, immobiliser and tracker.
Hard to forget a big red plug in key on your key ring I'd have thought?But everytime you forget you have to replace the fuse. Double edged sword.
And switches on military aircraft that have to be wire-locked to stop the pilot/navigator 'playing' with certain electronic equipments they shouldn't be.Such critical switches in an aircraft have to be fitted with a guard, which stops inadvertent operation as the guard has to be lited to operate the switch.
Geoff
How do you put your keys in your pocket with a big red plug attachedHard to forget a big red plug in key on your key ring I'd have thought?![]()
