Good Afternoon Folks,
We have a leaking tap in the kitchen. I’ve taken it apart and although there is some mild corrosion on the top threads, the seals look in good order. I’ve tried ptfe on the upper threads but there is a small leak below the ‘collar’ of the tap neck.
i was next going to take off the lower seals and ptfe in the grooves then put the seals back.
Any other suggestions on this type of tap?
