another fiat recall ggrrrrrrr (1 Viewer)
skylinersi
1,186
952
midlands
Van conversion
newbie
just checked the camper app, another red light!
i assume its for the intercooler clip?, which is mentioned on the chassis section under fiat,
anyone have any more details?
Sep 12, 2016
2,267
5,038
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
Just checked a recall site and this is what they have on
Number Date Concern
R/2017/283 2017-11-30 EGR PIPE COULD FRACTURE DUE TO A POTENTIAL NON-CONFORMITY
Number: R/2017/283
Date: 2017-11-30
Concern: EGR PIPE COULD FRACTURE DUE TO A POTENTIAL NON-CONFORMITY
Defect: The EGR pipe could fracture due to a potential non-conformity the fractured pipe may damage the alternator resulting in a loss of battery voltage and potentially a loss of engine power.
Remedy: The pipe must be checked and if incorrect replaced with a new part.
# Vehicles: 1336
Manuf. Ref: 6152
Vehicles Affected
Model VINs Dates
DUCATO 02A59559 to 02F21177 2016-02-17to 2017-09-13
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
Number Date Concern
Number: R/2017/283
Date: 2017-11-30
# Vehicles: 1336
Manuf. Ref: 6152
Vehicles Affected
Model VINs Dates
hi
we have had that one sorted so i assume its this later one, i will call fiat tomorrow and check
will post results on here ...........
Oct 17, 2016
453
376
Cheshire
A-class
40 years caravanning. New A-class Moho owners
Had my clip sorted last week. Was in there an hour. I had phoned earlier and as the Moho had been in before, knew which recall it was from the vin number. Mike
Oct 17, 2016
453
376
Cheshire
A-class
did they have the parts in stock?
Hi. Don’t really know. They booked me in for a week later and said they would contact me if anything changed, so maybe they didn’t. Find them easy to deal with. Scania Trafford Park, Manchester. Mike
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
ok, no probs, looks like its an order parts in and go back then
soreeyes
351
136
Sunlight T69L 2017
im a newbie
Took two weeks to get mine booked in for the clip but had to phone round to find a garage that could do it as some quoted May and June . It only takes a few minutes to do it .
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
does anyone have any pics of the affected parts so that we can check?
BillandHelen
852
2,142
Edinburgh United Kingdom
Wildax Elara
since 2004
Hi Skylinersi, yes it’s an order in job, my Fiat Pro Dealer says it’s two separate clips to support the inter cooler. No problems with continuing to use the van and it’s a 15 min job, our van similar to yours. Going to get ours done at same time as first year low mileage service in April.
Bill
soreeyes
351
136
Sunlight T69L 2017
im a newbie
I thought a red warnings (traffic light) on the recall would indicate the vehicle should not be used and fixed by the garage asap ?
My vehicle now shows a green traffic light after getting the clip done.
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
Bill
Top man !!
Thank you very much(y)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Local Fiat Professional dealership described the latest (clip) recall as the least of my problems compared to the EGR pipe and Heat Exchanger replacement that's needed.
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
Please tell me you're joking..... what's this heat exchanger problem??????
Lenny HB
53,430
149,982
On the coast in West Sussex
Hymer B678 DL
Red just means contact a service centre.
After having mine checked for the EGR bracket it took about a week to go green.
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
Was that after it was fixed???
magicsurfbus
4,673
10,127
NW England
Since 1997
To cut a long story short mine's been in for a second check after the initial EGR pipe check and they've said the heat exchanger needs doing too. The first check was mid-December, and to date nothing's been fixed due to supply chain delays. Their original plan was to check the heat exchanger during the pipe replacement, but that would have dragged it out too long. I think they're trying to speed things up.
I should add that it's not a foregone conclusion that both components will need replacing, but they're checking both at the service centre I'm dealing with.
BillandHelen
852
2,142
Wildax Elara
since 2004
Magicsurfbus, I assume these two issues are separate? My understanding from my dealer was that the EGR pipe if “burst” and I continued to drive the van could cause damage to the alternator wiring, possibly resulting in loss of power and severe damage. Clearly we decided not to drive it till all replaced!!
But no mention of heat exchanger?
Bill
Dec 23, 2015
444
522
Audenshaw
Pilote Pacific P650GJ
Over 6000 miles between 3 March to 26 September 2017.
The heat exchanger problem can be caused by the EGR pipe being split. We saw the photos of our 'cracked' heat exchanger that had to be sent to Fiat in Italy before they would authorise replacement. It was more of a hole than a crack . I asked at Trafford Van Centre how many they'd had in where the EGR pipe needed replacing - including ours, 12. How many needed the hear exchanger of these - 8 :eek:.
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
It just gets better..........Oh Please!
magicsurfbus
4,673
10,127
NW England
Since 1997
Like @Diggerdi I'm also dealing with Trafford Van Centre, and so far I've been impressed with their diligence. Maybe now they've done a few they're expecting a 66% failure rate and trying to anticipate things, but they're hamstrung by supply uncertainties. It could impact on our holiday plans but I can't see how getting in a strop about it's going to change anything.
Obviously I still have to drive ours to get it to Trafford. It's also got a service and hab check due soon to stay within warranty. It's done 6000 miles since it was bought, and so far nothing drastic has happened, but if the fix needs doing it needs doing.
skylinersi
skylinersi
1,186
952
midlands
Van conversion
newbie
ok, update......
spoke to fiat customer services via the app, yesterday, and was told there is a recall, bit vague on what it was, so contacted platts in stafford who are now aware? and will order parts, and contact me to get sorted.
i decided i would like to know what the recall / fault(s) is / are, so again contacted fiat customer services.
different person, very different attitude sadly....
i was told not to contact any dealer / workshop regarding this until i get the official letter from fiat. they refused to tell me what it was affected by the recall, and just told to wait. I pointed out that the letter arrived a month after we had the egr fix done!! last time. no response other than wait for letter, so i asked are we ok to use the van, told yes, carry on as normal and if any problems to contact them (customer services / camper assist) again and they would sort it, regardless of country we may be in.
They say the letters are mailed 'strategically' to allow dealers and workshops to get the repairs done without creating a backlog etc, or words to that effect.
So we get a red warning on the app, told to contact them immediately, and then thats the response you get........glad i dont run my business like that...........
Lenny HB
53,430
149,982
Hymer B678 DL
Took mine in for the intercooler pipe clip this morning, a pig to get at on an A Class as it's buried down behind the radiator but only took them 15min.
Mar 21, 2010
2,486
2,993
In Spain at present, had to call Fiat Assist as we lost power (no warning lights) as luck should have it we stopped outside a Fiat main dealer. Saturday afternoon,so nothing done until Monday. When Fiat put their computer on the van they found “no problems” quite embarrassing!
Off we go, two days later loose power again which is dangerous, quickly switch off/on and ok for a couple of weeks. Again loose power cure was to switch off/on and everything ok and now two weeks later no more problems.
When we had our last MH which was a Ford Transit we had exactly the same problem, Ford could never find the problem. Our cure was to switch on/off and everything was okay.
Just by chance someone suggested “has it been calibrated?”. Took it Ford who calibrated it (don’t know what that is) and never had anymore problems.
When we get back to UK will contact Fiat. I wonder if this may be the answer?
Anybody had this problem?
Colyboy
Lenny HB
53,430
149,982
Hymer B678 DL
Just an update the traffic light on the app has already gone Green.
