I'm seriously considering going the Alde route in our next van, but I'm unsure on a few things and could do with some help.
This van will be for fulltiming. I like the cold and snow sports etc - the Missus and dog don't
If I'm to stand any chance of talking her into spending weeks in the cold I'm going to need to make sure she is toasty at all times.
Firstly, I remember on our first van (an older Pilote A-class) the frost control would trigger quite often, emptying the water. That van had a much older heating system and I'm sure the Truma Combi 6E would be much better, but would the Alde be better again?
Next, Heat Exchanger?
I understand this enables the van to be heated via the engines cooling system whilst driving.
How well does this work?
One of the arguments against the Alde seems to be it takes longer to heat up the van. If running it whilst driving with the Heat Exchanger, is this an issue?
I know the Truma can also be used in transit (with crash sensor), but would obviously run off gas.
Still on the Heat Exchanger, I see another option is a pump to pre-heat the engine. What are the advantages of this?
Sure I read somewhere that this clears condensation from the windscreen or something like that. Is this the case? If so, how? Does it use a fan or something? (confused on this one)
Along with the above Alde options, the van I'm looking at has an option for adding a small Truma heater with the Alde. Not sure why this is an option. Any ideas?
Does the Alde use more/less gas than the Truma, or are they similar?
I see that Alde do a heated towel rail. This would definitely score me brownie points
Does this work well?
Are there any other advantages/disadvantages with the Alde compared to the Truma in more extreme climates?
Thanks.
Thanks.
