Christow Dave
help just been out to the van and I noticed the fluid in the heating header is vigorously bubbling. it is a aide 3010 system in a Bailey approach it has not been powered fo a few weeks. can anyone advise
I don't know at the moment I have just powered it up to see what difference that makes
The heating fluid stays in as it contains anti freeze. I drain the water if we are just doing days out and then fill up if we are stopping away in it.This might sound silly or stupid or maybe even both. Do you have to drain the entire system down over winter as you would a warm air blower system.
As Mr Colpot says, the 'heating fluid' is basically antifreeze (G13 spec)/ distilled water mix (of around 50/50 mix) - there are lots of youtube videos on how to change your own fluid, though i dont think what Alde charge is excessive.This might sound silly or stupid or maybe even both. Do you have to drain the entire system down over winter as you would a warm air blower system.
Yes thanks it was the pump . But the boiler is not heating. And the pump won't switch off turning off both the heating and the master and it just keeps going. The only way to stop it was to pull the fuse on the system. Any ideas on what's going on?
As I suggested earlier, perhaps you could ring ALDE tomorrow?Yes thanks it was the pump . But the boiler is not heating. And the pump won't switch off turning off both the heating and the master and it just keeps going. The only way to stop it was to pull the fuse on the system. Any ideas on what's going on?
If you go to menu and settings you can check if the pump is set to on all the time - I think the settings are on/auto/off. Its normally set to auto so it only comes on when needed but worth checking?Yes thanks it was the pump . But the boiler is not heating. And the pump won't switch off turning off both the heating and the master and it just keeps going. The only way to stop it was to pull the fuse on the system. Any ideas on what's going on?
The service engineers changing the fluid usually turn the pump speed to max to speed the process . They often forget to turn them back down once completed .Ours has bubbled since the fluid was changed. Water still works fine so livung with it. Will get Alde to change it next time.
I thought that but the Engineer says its set as it should be. It works ok and I have learned to live with it.The service engineers changing the fluid usually turn the pump speed to max to speed the process . They often forget to turn them back down once completed .
Our headed bubbled like mad until I found the pump speed was at max
I spoke to Alde HQ and they told me that the header tank shouldn’t be bubbling so I turned the speed down on my high speed pump to a point that the bubbling stopped but the pump was still running.I thought that but the Engineer says its set as it should be. It works ok and I have learned to live with it.
Was the adjustment on the pump itself?I spoke to Alde HQ and they told me that the header tank shouldn’t be bubbling so I turned the speed down on my high speed pump to a point that the bubbling stopped but the pump was still running.
I also think the excessive bubbling was actually causing fluid evaporation and I needed to top it up too often.
Yes . On my set up ( a high speed pump) it’s a red screw located on the pump located on the side of the ALDE unit itself anti clockwise turns is reducing the pump speed .I can send you a picture tmw if you need ?Was the adjustment on the pump itself?
Looks like thisYes . On my set up ( a high speed pump) it’s a red screw located on the pump located on the side of the ALDE unit itself anti clockwise turns is reducing the pump speed .I can send you a picture tmw if you need ?
