I'm having my blue pumped out and Pink pumped in at Home next week or so but my Aldi engineer only covers New Forest area noorth of Bournemouth up to Salisbury.
What sort of cost is it at the Aldi HQ in Northants?
Why not book in at the factory like many others do ?
Alde
Wellingborough
Northants
NN8 6AB
Tel: +44 (0)1933 677765
E-mail: info@alde.co.uk
A second vote for a visit to the Alde factory ... they are really professional, have all the correct parts and tools, reasonably priced and you can overnight in their yard.
.....and another vote. They also sorted a sensor problem which I doubt that a local engineer could have done. The technician said he had only seen the pr once before but knew how to fix it (10 minute job). Very good people to deal with.Definitely not worth messing around with anyone else just go to the Alde headquarters as others have said ?
I am no expert on the chemistry of antifreeze but the Motorhome manufacturers use basically the cheapest rubbish available which has a short lifespan of 2 or 3 years depending on manufacturer.I think you will find its car/ vehicle antifreeze, do you change your car/ motorhome antifreeze every 2 years? Do I have leaks sprouting out my 9 year old Volvo XC60 ? No
I can promise you that they don’t have the same equipment available to them that the Alde factory boys have ?Had ours done two days ago at Nick Whale Motorhomes Near Evesham Worcestershire.... great job done.. using all the correct equipment too..
https://www.nickwhalemotorhomes.co.uk/
It is nice to hear something good about themHad ours done two days ago at Nick Whale Motorhomes Near Evesham Worcestershire.... great job done.. using all the correct equipment too..
Ours was in for warranty work that a dealership couldn’t fix and got fed up waiting, Alde just swapped out controller and main pcb and sorted the non working booster fan and secondary pump on heat exchanger that didn’t exist according to the dealers.....and another vote. They also sorted a sensor problem which I doubt that a local engineer could have done. The technician said he had only seen the pr once before but knew how to fix it (10 minute job). Very good people to deal with.
if you want a local place, I believe that both Chichester caravans in Upton Warren 200 yards from my storage) or Broad lane leisure have engineers, but you have to ask yourself why I didn’t use them.......
Alde do a flush without draining the system but put loads of water through then replacing with correct fluid And bleeding the radiators. Draining apparently causes lots of air locks which are a pain to remove
It's an all aluminium system. Following the recommendations for servicing is a good idea. Five year antifreeze & de-ionised water isn't expensive. Much better to use the 5 year stuff, stick to changing it at five years, and DiY.I think you will find its car/ vehicle antifreeze, do you change your car/ motorhome antifreeze every 2 years? Do I have leaks sprouting out my 9 year old Volvo XC60 ? No
I’ll add my vote for Alde UK too.
Had our fluid changed a few weeks ago as the van is coming up to five years old.
Spent the previous night in their yard, all very quiet and peaceful.
The guys there really know their stuff and it was a pleasure to deal with them, very professional.
As others have said, they check the whole system thoroughly and found a couple of things that might have become a problem in the future. All sorted now before we get let down somewhere in darkest Europe.
The system is now running beautifully and is much quieter than before. It was money well spent.
Richard.
Glad you are happy with the job ?
We went around a few local Motorhome dealers looking for someone to carry out our service, hab check etc and thought them by far the most professional.... and very happy with there standard of work and customer service...others may have different experiences but can only report on what we found....
In the HQ they had a very large tank for the flush water and flushed it for about 30 minutes, then flushed through with fluid from another very large tank. They also isolated parts of the system to ensure ensure it was properly flushed. He pointed out that this was important as the fluid tends to go where it is easiestBeg to differ....all that is required to correctly change the fluid is a specialized Alde pump (which they have) that is used to pump the replacement fluid around the system....other than that all that is required is the correct Alde pink 5yr fluid.... they even supplied photographs of the job being carried out....like I said more than happy thanks..
I know exactly what is required and I also know what equipment Alde have at the factory and I can promise you that they are completely different but yes for a dealer probably adequate.Beg to differ....all that is required to correctly change the fluid is a specialized Alde pump (which they have) that is used to pump the replacement fluid around the system....other than that all that is required is the correct Alde pink 5yr fluid.... they even supplied photographs of the job being carried out....like I said more than happy thanks..
Which is therefore an interesting question....where do these "service bods" go to be trained in servicing Alde equipment...and if after having the training by Alde if they are not up to the required standard would they actually be accredited with being Alde service centres/ agents.....maybe its a cunning ploy to not train them or equip them well enough to do the job thereby generating loads of repair work for the Alde centre themselves.. interesting question..I know exactly what is required and I also know what equipment Alde have at the factory and I can promise you that they are completely different but yes for a dealer probably adequate.
Many of the vans that end up at Alde are problematic warranty claims normally from badly installed systems by manufacturers or bodged up work by service bods ??⚠
I only tried to point out that the factory has specialist equipment and knowledge that dealers don’t have.
Alde boys are also Gas Safe Registered unlike most dealers who are just NCC ??
Lots of Radiators are alloy , I was fleet Engineer for a brewery we never changed the antifreeze on any Volvo nor Scania's from 1983 to 2005 only time we replaced a Radiator is when a stone or something went and damaged them , checked the strength and topped them up yes, some people used to stick their finger in it and taste it to see if the system had antifreeze in , but that is dangerous as once in your body it's always in the Body .It's an all aluminium system. Following the recommendations for servicing is a good idea. Five year antifreeze & de-ionised water isn't expensive. Much better to use the 5 year stuff, stick to changing it at five years, and DiY.
