Alde 3010 Panel went blank but came back on (2 Viewers)
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
I have drained the water down on the Alde System and went out in the van today,parked up and put the heating on gas. Heating worked for a while but then we realised it wasnt working. Control panel was blank and wouldnt respond. Leisure & Vehicle batteries were showing 13v when the panel went off.
Drove home and when I parked up I saw the panel was on and the van had heated up to 24 degrees. I turned it all off. Have searched on here but can only see threads relating to permanently blank panel. Checked the manual I have and cant see any reason for it happening. Any ideas as to what may be the issue?
Apr 9, 2018
8,647
44,730
Worcestershire
Bailey Adamo 75-4t
March 2018
This may not be your situation but on our caravan we had a blank panel and then it worked, blank/work etc for a few times until it would not work at all.
Inside the heater unit is a PCB and on that there is a thermal fuse that gradually fails. Eventually failing completely.
The PCB was about £200 and a new thermal fuse £0.99. If you are skilled at soldering onto PCBs then it is worth a shot.
Mr Colpot
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
Mr Colpot
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
Thanks David and Sally I have read that thread so may grab a spare before it goes although I still have some warranty left so may go down that route
