deleted79651
- Mar 9, 2021
- 2,279
- 6,142
Decided to change the [original 5.5 year old] vehicle battery [which was dropping to around 12v after 5 or 6 days] some 2-3 weeks ago to avoid the risk of an ECU failure. Unforunately, the new battery was faulty, and 6 days later, the ECU failed! Sod's Law ...
No ECUs available in UK, and Crashdata said Fault Code suggested the original ECU was damaged beyond repair. Managed to get an appointment at a local auto electrician for yesterday, to confirm that it was the ECU, and that it needed a replacement rather than repair. Electrician confirmed that new ECU was needed, BUT he managed to find one already in UK and he has fitted this morning, along with a [third] new vehicle battery, Yuasa 950 amp 5 year guarantee and has tested the charging system from nose to tail to ensure that there are no other problems lurking ... He did identify a continual drain on the vehicle battery that seems to stem from the Lithium Leisure Battery being at too high a cutoff [Winter] charging rate in Scotland to allow the Battery Master to obtain any spare energy from the Leisure Battery to keep the Vehicle Battery topped up. The Lithium Battery caused no problem in Summer with hours of high yield sunlight to keep both batteries happy.
I don't know whether the Lithium App can be switched around to a lower Charging Cut Off in Autumn/Winter and the returned to its default setting in Spring/Summer to limit the life shortening reduced charge supply for the Leisure Battery. Electrician keeping the Van for another night to check that his changes have removed the drain on the Vehicle Battery. I'll probably need to sell a kidney to pay the bill for ECU, Battery and Labour + VAT etc, but I can at least begin to think about rebooking last week's cancelled Ferry Crossing ...
Steve
Steve
