Mountain man
Wondering if anyone knows if there is such a thing as an external air intake cover for Fiat Ducato 2020 .As when it rains I often find water in my air intake under the bonnet.
I was meaning the engine air filter that close’s against the box under the bonnet or is that the same thing you described.?ThanksIts quite normal and not a problem. The air is taken upwards to the cab through the first corse filter and there is a hole in the bottom of the chamber to let water escape
We've got a set as well for our X250 however, as Wilf advises, they do not fully block water ingress (they're really to stop ingress of leaves, etc) however we solved this by "fixing" bits of kitchen cling film over the grills and then holding these in place with the covers.wiljoy was making a selling magnetic bonnet air intake cover a while back, I bought a pair.
Broken Link Removed
One of the culprits is the scuttle (the moulding at the base of the windscreen) which discharges excess water over the engine if the drainage holes get blocked or overwhelmed.
