Latest model is FWD and lighter (more payload). RWD gives better traction and turning circle.I think you can have either, the fwd is extra, not necessary then?
As you say, I can try without first as it can be added later, thanksThere are other ways to cook than a microwave and microwaves are heavy. You could install one in the garage and see how you get on but I wouldn't go having furniture changed to accommodate one until I was certain I was going to make good use of it.
EHU??12v or 240v?
I have a plethora of 240... and use about 3 if on EHU...
I’ve installed 3 extra 12v...
Tele
Usb’s for charging and iPad to watch stuff whilst in sack...
You should not need extra heating with either. Both will keep you warm in the winter. Probably worth getting the combined electric and gas if you will be using campsites in UK.Is additional heating worth thinking about, or is that something we can have added at a later date?
electric hook up as in mains electric on a campsiteEHU??
Good advice. On the oven front, I was thinking of no oven but possibly a microwave tho I have seen some people think that is a waste. Was thinking of baked potatoes and veg you can steam in a microwave in minutes. I'm very aware I'm being very female here and appreciate your patience
solar panels and extra batteries are essential
Not necessarily. It depends on what its already got. We've used our Swift Firebrand at all times of the year. Just changed the gas to Gaslow so we can get it anywhere in Europe. we don't do much wildcamping, aires etc so generally use hookup. We did check out solar panels a few years ago anddecided it wasn't worth the outlay for us although might be worth it for other people.solar panels and extra batteries are essential
Yup, much pondering is going on! Really grateful for all this advice. Need to get husband to think about engines etc, like the idea of getting the extras that need to be fitted at manufacturers and then seeing how we go. Again, many thanks xI bet your head’s spinning now, Sara? Ponder on what’s been said. Unfortunately, there isn’t a common view because we’re all different and use our vehicles in many different ways.
Don’t be frightened to come back and ask more questions when you’ve had time to think. I suggest you raise different ones as different posts/threads to keep discussions focused on one topic at a time.
You’ll need to be patient if buying new. The lead times are not something to be holding your breath for but, if you do, I’m sure it’ll be worth your wait!
Solar panel the first thing we had to add on, surprised all modern MH don’t have them as standard. The alarm on ours runs the cab battery down in 3 weeks. The solar panel keeps both cab and habitation batteries in good condition.Not necessarily. It depends on what its already got. We've used our Swift Firebrand at all times of the year. Just changed the gas to Gaslow so we can get it anywhere in Europe. we don't do much wildcamping, aires etc so generally use hookup. We did check out solar panels a few years ago anddecided it wasn't worth the outlay for us although might be worth it for other people.
Steph
Not necessarily so.....it depends on how many amps are provided by the hookup.When “plugged in” .... say on a campsite... it’s like being “at home”...
Insofar as anything you carry in moho.. toaster... will work....
