Advice please; Hymer dump valve problem (2 Viewers)
offwego
18
7
France
Hymer T656
I am a newbie
Hi all,
Hoping that some of you experienced funsters can help with a fresh water dump valve fault.
In May this year, I purchased a Hymer T656, which was first registered in November 2007. In preparation for a winter lay-up, I attempted to drain down the fresh water tank only to find that the dump valve was seized. As I live in a hard water area of France, I believe that a build up of calcium carbonate around the valve(inside the tank) has caused the seizure. I think that the previous owner must have had difficulty in opening the valve since the square brass shaft (on which the operating wheel sits) has been damaged.This is shown in pic 001.
I have managed to expel most of the water by opening the sink and wash basin taps and letting the pump do the rest.
I believe that this model of motorhome was not sold in the UK, but I am sure that Hymer vans imported into the UK (circa 2007,2008) would have had a similar if not an identical fresh water system fitted.
My questions are as follows:-
a) Would it be worth trying to free up the dump valve with a solution of vinegar and water and/or gentle tapping? I ask myself the question, if this is what has happenend to the valve in what state is the pump, although at the moment it appears to be working fine.
b) Is the complete dump valve assembly a replaceable item ? There is some access to the shaft inside the tank, which may just be visible in pic 004. I have not been under the van to see what part of the mechanism is visible from there.
Most grateful for any advice or your experience of this problem.
kind regards,
offwego
philk
173
50
Lancs
since 2000
dump valve
hi offwego,
From memory, the shaft or the valve is square, have you tried turning the valve using the shaft and also, try turning it backwards.
Philk
O
offwego
18
7
France
Hymer T656
I am a newbie
hi offwego,
Philk
Hi Philk,
Thanks for your reply. You are correct, in that the part of the shaft visible outside the tank is a square brass shaft onto which the operating wheel sits. As this shows some sign of damage already and it does not appear very strong, I am reluctant to try and turn it by force in case it shears.
Inside the tank, there appears to be a cylindrical keyed shaft which opens/closes the valve. I have tried turning this by hand without any success. Perhaps the idea of soaking overnight in vinegar may loosen up the mechanism.
regards,
offwego
Allegro83
67
44
Balfron, Stirling
East Neuk Fifer L
15 years
We use a solution of water/wine vinegar in ratio 2/1 to descale the hot water boiler however you then heat the water. Same with the kettle when we have been to France/Spain. Could you add hot water/wine vinegar and then leave overnight?
Jan
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Just add the water and vinigar
Drink the wine
You wont care if it works or not:ROFLMAO::ROFLMAO:
JockandRita
11,469
150,328
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Soaking in neat vinegar overnight may work.. if not, measure the diameter of the valve and buy a new one from CAK tanks... http://www.caktanks.co.uk/
Hi Jim,
I am sure that this is a Hymer specific item, and it doesn't appear to be available from Broken Link Removed.
Being an older model, ours is just a wee plug on the end of a chain. :Smile:
Cheers,
Jock.
